Hi
I would like to cut out a rectangle draft (abt 15deg) on a 15mm thick.
My procedure is as follows:
1. Relief the rectangle and draft the angle
2. Perform a cutout the material using endmill on a smaller vector
3. Perform a Z level roughing with the 2 vectors selected
The problem is that if I perform step 3 the tool path generated will try to finish the inner vector and this waste 50% of the time.
Is there a way to label the inner vector as a keep off area or other method to machine this rectangular draft?
Or any 3D cutout can follow the draft?
thank you
Benson
