588,342 active members*
4,975 visitors online*
Page 1 of 8 123
Results 1 to 20 of 142
    Oct 2009
    867
    A Desktop CNC by David A
    Hello everybody,
    This is my build thread for a desktop CNC. It features rotating ball nut drives throughout and is designed to incorporate coolant and vacuum cutting.
    Mechanical design goal was to maximize planar loads, thus I am calling it PLANAR.
    Enjoy.
    Oct 2009
    867
    Re: A Desktop CNC by David A
    Starting point is the pan with a T-slot table.
    It is watertight and can hold about two gallons of coolant and has vacuum channels built-in.
    Oct 2009
    867
    The pan has six rows of bolts for stringers.
    Oct 2009
    867
    Installing first outside stringer below the pan.
    Oct 2009
    867
    Stringer pushed through.
    Oct 2009
    867
    Installing gauge on stringer.
    Oct 2009
    867
    Line up gauge with the end of stringer and tighten down.
    Oct 2009
    867
    Push stringer with the gauge until it touches the pan.
    Attachment 504828
    Oct 2009
    867
    First stringer is installed.
    To install stringers under the table, loosen one row of bolts with the T-nuts.
    Attachment 504838
    Oct 2009
    867
    Inside stringer pushed under the pan.
    Oct 2009
    867
    Again, use gauge to push the stringer into correct location and tighten back the bolts.
    Oct 2009
    867
    All stringers are attached under the pan
    Oct 2009
    867
    Next up are the uprights. A pair of side plates and one upright profile.
    Attachment 504972
    Oct 2009
    867
    And the installation jig.
    Oct 2009
    867
    Install side plates on the stringer.
    Oct 2009
    867
    Push the jig under the side plates until it touches the stringer.
    Attachment 504978
    Oct 2009
    867
    Jig brings the side plates to the same height and aligns them with the front face of the stringer.
    Oct 2009
    867
    The upright profile has a notch at the bottom.
    Oct 2009
    867
    Slide the profile down between the side plates with the notch facing toward the pan.
    (Front side plate omitted for clarification.)
    Attachment 504996
    Attachment 504998
    Oct 2009
    867
    Install brackets on both sides of the upright.
Page 1 of 8 123
  1. David A's Benchtop CNC Version 2
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 09-09-2021, 02:08 PM
  2. Replies: 0
    Last Post: 06-06-2018, 01:50 PM
  3. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum For Sale Only
    Last Post: 09-18-2015, 09:05 PM
  4. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum News Announcements
    Last Post: 04-28-2015, 11:23 AM
  5. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
