I have a Dyna Dm2400 and it requires 101000 steps per unit approximately. The steppers are old Portescap P532 258 0.7 14. http://www.dracon-eltron.com/Engels/...agnet/P532.pdf
Right now I have them connected in series which according to the specs is 2.4A. That is what my current set resistor is set at (adjustable 1 on the Db9). They are working however I dont know if this is the best they can operate or not. The spec sheet also shows when in parallel the are 3A. Since the G540 is capable of 3.5A per axis, correct? Would it be better to wire them in parallel? Would they be faster at the cost of torque? Just to throw some other details in, the PS is a 24V @ 4.5A. This came with the machine and I will upgrade if necessary but would like to optimize with what I have also. Also arent the relay connections on a G540 switching the ground and not the positive connection?
