587,584 active members*
3,673 visitors online*
Results 1 to 6 of 6
    Apr 2007
    9
    Red face Thread milling help!
    I want to make a programme for inside thread milling by interpolation method using single point thread milling cutter ......
    how can i make programme for 28 mm inside core dia with 1 mm pitch in 25 mm depth........
    If i have got dia 10 mm single point HSS cutting tool.
    Jul 2005
    12177
    This program has the Work Zero at the center of the hole and Z zero at the top of the material and it uses Tool Compensation which is entered by the G10 command. I have not accurately calculated the diameter for the thread so you would need to do that, I am just using 30mm to make it easy. Also this is just the thread milling part so you would need to interpolate the hole first.
    G10 L12 G90 P1 R10.0 Enter the tool diameter
    G00 X0. Y0. Z1. Move to the hole center
    Z-25.0 Move to the starting depth
    G41 D01 G01 Y10. F25. Set tool compensation but do not enter the cut yet
    G03 R12.5 Y-15. This does a halfcircle counterclockwise so the tool enters the cut tangentially and ends at a radius of 15mm G91 G03 I0. J15. Z1. L26 This does 26 circles incrementing up 1.0mm at each circle so the tool ends above the work
    G90 G40 Y0. Z1.0 This changes back to absolute, cancels tool compemsation and move clear of the work
    Apr 2007
    9
    thanks you *Geof* i have made the same programme myself ... i wanted to know more techniqs..... anyway my job is done thanks again.
    Feb 2007
    11
    try this website www.advent-threadmill.com/
    I use their software for 90% of my thread milling
    dandy
    I know that one of our tool suppliers has a neat little porgram that you can download from there site.. the company is ISCAR.
    Feb 2008
    19
    thread milling macro
    try this I use it on fanuc O-M + 18
    It is in metric but can be used for imperial as well
    T1
    M6
    G0G54X0Y0S2000M3
    G43Z100.H1M8
    M98P4000
    G0X50.
    M98P4000
    Z100.
    M30
    :4000 (THREADMILL)
    #100 =-62.(START DEPTH)
    #101 =10. (RADIUS OF THREADMILL)
    #102 =42.(DIAMETER OF THREAD)
    #103 =150 (FEEDRATE)
    #104 =2.(THREAD PITCH)
    #105 =12.(TIP LENGTH)
    #102 =#102/2.
    #102 =#102-#101
    WHILE[#100LT0]DO1
    G1 G90 Z#100 F500
    G1 G91 X#102
    G3 G90 I-#102 Z[#100+#104 ]
    G01 G91 X-#102
    #100 =[#100+#105+#104 ]
    END1
    G0 G90 Z10.
    M99
  1. Thread Milling
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 08-02-2011, 12:48 AM
  2. 0M-Thread milling?
    By mikul in forum Fanuc
    Last Post: 12-06-2006, 06:56 AM
  3. thread milling
    By STS_Kevin in forum Daewoo/Doosan
    Last Post: 11-29-2006, 01:50 AM
  4. Thread Milling 3/8-18 NPT
    By shawn in forum G-Code Programing
    Last Post: 08-26-2006, 02:24 PM
  5. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
