588,058 active members*
5,222 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > PCB etching tool ? Runout Problems.
Results 1 to 8 of 8
    Jan 2007
    61
    I’m looking for a cheap simple & small drill type solution for etching PCB’s
    I’ve tried using a dremel tool with the long cutter cable attachment, but there is way too much runout. Even on the regular dremel tool, there seems to be two much runout. I need somthing small, not a big tool.
    What should I buy ? I also need a tool head holder for it.
    Jun 2003
    3312
    do you mean milling a pcb?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2007
    61
    YES, I need a good small and aforadable tool (spindle) for milling PCB's.
    Everything I have has to much runout on my DIY CNC machine.
    Also, I'm having Z depth problems (Leveling)
    Any suggestions ?
    I'm thinking of trying to build my own, kinda like this...
    http://www.buildyouridea.com/cnc/spi...pindle_05.html
    I'm going to start with an old dremel tool I think.
    Jun 2003
    3312
    Might try Paul at www.cnconabudget.com. I have one of his and it works really nice.
    Jun 2003
    3312
    Also to get narrow traces and isolation you need a flat surface. 2 mils tops.
    Jan 2007
    61
    Yes, I've been having problems milling the depth on my PCB.
    At one point I set the drill depth to z-0.0100 and it works fine,
    but only for a trace that is halft the length of the board, then
    it just scratches the surface for the other side.
    I tryed placing 4 screws on my work area (one at each corner)
    then I adjust each screw up or down, but it will never route
    at the same depth ?
    I'm stumped ? I'm on the verge of failure because I cant get the
    Z depth set correctly
    Thanks for any help.
    Jun 2003
    3312
    Milling quality pcb's is a little more difficult that at first glance it would seem. 1st mill your mounting area flat. That will help. Mounting area needs to be stiff. There is no room for backlash. Either mechanicaly get rid of it, or use the backlash adjustment settings of your software to minimize it.
    Jul 2006
    17
    Wink PCB Tooling
    Hi
    Have a look for cutplot on ebay they do just what you need the V shaped cutter allows for very small grooves whilst maintaining rigidity, all the best.
  1. HELP Tool changer problems
    By ddprecision in forum Haas Mills
    Last Post: 07-18-2016, 02:30 PM
  2. Fanuc 15m Tool Change Problems
    By diggityds in forum Fanuc
    Last Post: 12-20-2011, 12:49 PM
  3. Haas VF8-50 Taper Tool Release Problems
    By SheldonB in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2007, 06:03 PM
  4. Partner I Tool Change Problems
    By Outlaw6700 in forum Milltronics
    Last Post: 02-26-2007, 05:33 AM
  5. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
