588,507 active members*
4,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport VMC800 - Heid 426 control - Tool Length Offsets
Results 1 to 19 of 19
    Jan 2013
    27
    We have a Bridgeport VMC800 with heidenhain 426 control. We are using a datum cutter and then bringing
    all the other cutters around and touching on the same Z zero height, then using the capture button to insert
    the z offset into the tool table. But then when you are programming the machine is there a way to get the machine
    to use the offsets in the background and display each cutters depth from the z datum of the job (ie, the datum cutter z zero).
    This is how we work on the Hurco machines we have, so I would think it was possible with the Bridgeport, just dont know how to do it!!
    Mark Newton
    May 2012
    180
    Re: Bridgeport VMC800 - Heid 426 control - Tool Length Offsets
    If you mean that the screen value is relative to the end of the tool then it's changeable in the parameters.
    You'd have to wait till Monday for me to find out which one it is.
    Jan 2013
    27
    Hello
    Yes that is what I mean. That would be great if you could let me know Monday. And also do you know how to get into the parameters!!!
    Cheers
    Mark.
    Jan 2013
    27
    Also why we are in conversation. Do you know how you can view the graphics of your program before you run the program. At the moment
    we are running everything blind!!!
    Thanks.
    Mark
    May 2012
    180
    Top of your program do you have a block form?
    Jan 2013
    27
    Yes we have a block form.
    May 2012
    180
    Right.
    If you have a nc-software book, this information is on page 327.
    can get the book on heidenhain website i believe.
    To enter parameters you need to be in program edit, then press the MOD key. code is 95148.
    take your time and double check everything...
    Check you are in OVERWRITE which is a toggle on one of the softkeys.
    Press GOTO, 7285 , ENT.
    This figure needs to be a 1, so highlight the 0 and press 1.
    Now press END, END
    From now on when setting a datum, make sure you have tool called the tool you are setting with - Take your time until you get used to it.
    If you use tool tables rather than tool defs in the program then its easier to see.
    As for the graphics, what have you tried, or what do you think is not working?
    All the best ben
    Jan 2013
    27
    Hello Ben,
    Thanks very much, I will go and give this a try.
    The graphics will run when the program is started. But is there a way of generating the cutter path in a the test run to give you
    a guide to see if the program is ok? And to see the finished result without running the actual program.
    Thanks very much so far, its apprecited.
    Mark
    May 2012
    180
    So have you tried the test run.
    Button usually below program edit. Start and stop it with the soft keys.
    Jan 2013
    27
    Hello Ben. Thanks for the info for setting the tools. That has worked a treat.
    We will be investigating the graphics soon and I will get back to you.
    Thanks again.
    Mark
    Jan 2013
    27
    Hello Ben,
    When we are in test run we have just a blank screen with no program edit/start/stop buttons. In program and editing we get the graphics but it is just the
    block form. What we are trying to see is the simulation of the toolpath we are going to be cutting.
    Thanks.
    Mark
    May 2012
    180
    Can you take a picture of your control in that mode please.
    Jan 2013
    27
    Hello Ben,
    Please see attached, its just really a blank screen!!
    CheersClick image for larger version.
    Mark
    1121
    IIRC hit one of the little circle jerk buttons it should give you display options
    Jan 2013
    27
    One of the circle buttons returns you to the program and editing screen, the other does nothing?
    May 2012
    180
    Does the pgm mgt button do anything?
    Jan 2013
    27
    Hello Ben,
    All sorted now thanks. The guys have resolved the graphics issue.................somehow!!
    Thanks for all your help.
    Kind Regards
    Mark
    May 2012
    180
    Any ideas what the issue was. Cheers.
    Jan 2013
    27
    A local guy came in and pressed a few buttons and got it working!!!
  1. Mach3 tool length offsets
    By Dstamp in forum BobCad-Cam
    Last Post: 07-15-2013, 12:01 AM
  2. EZ Trak tool length offsets..
    By derrickjf in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2012, 12:43 AM
  3. Tool length offsets
    By gbpacker in forum Fadal
    Last Post: 09-29-2009, 04:23 PM
  4. setting lathe tool length offsets on ah ha control
    By machinewerks in forum G-Code Programing
    Last Post: 02-28-2007, 04:09 AM
  5. Tool Length offsets supported?
    By HomeCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2004, 05:38 PM
