588,357 active members*
7,794 visitors online*
IndustryArena Forum > Community Club House > I from Russia. Me interest filament winding machines
Results 1 to 14 of 14
    Jan 2010
    6
    Where to find information about CNC winding machines (glass, carbon). Who has already manufactured: design, software, pictures, etc...Information about exactly self-made winders is required.
    Jan 2010
    4
    Zdrasvoyet ya drook.
    I am new here myself and can not help you much. I just want to welcome you.
    BTW.
    What part of Russia are you from?
    Jan 2010
    6
    Greetings, Val
    Thanks.
    My name is Igor
    I live in the city of Belgorod
    These are 700 km from Moscow.
    Almost on boundary with Ukraine
    Excuse, I badly understand English language
    Jan 2010
    4
    It's OK Igor. I speak a little Russian and have Russian and Ukrainian friends who speak very little English and have learned how to make up for our limits.
    Maybe that is where I can help you. If you get confused talking with people here, let me know and I will do my best to help with communication.
    BTW.
    Nice area you live in. I myself want to visit Petrograd some day around Christmas time. I lived in Alaska for years, so I am familiar with the weather.
    Jan 2010
    6
    Val,
    In Petersburg is much warmer than in Juneau
    I when was the USSR, served in the Air Forces in the Far East
    It is area from Japan up to Alaska
    On this site likely nobody will help me
    Filament winding machines and here a rarity
    Even books I can not discover on design
    Jan 2010
    4
    Quote Originally Posted by necom View Post
    Val,
    I heard that Petersburg is much like the British Columbia of Canada. Not a huge difference from where I was in Alaska, but noticeable.
    I have never even heard of the machine you speak of, but I am a writer which means that I am skilled at research. I will do what I can to help you.
    Please share any details that may help me help you.
    Jan 2010
    6
    Thanks for desire to help me
    Me calculation, constructing and design filament winding machine interests
    In the USA there are corporations which do such machines
    For example
    http://entec.com/
    http://www.mccleananderson.com/
    But it is greater machines for factories
    Me the machine self-made interests
    I wish to make such machine
    I think at it there should be 4 axes or more
    The length of an article is no more 2 meters
    The machine should know how to wind fittings for pipelines (elbow, tee and so on)
    Once again thanks
    Igor
    Mar 2008
    267
    Hello Igor,
    I used to sell coil winding machines ( copper wire inductor winding machines from Tanak Seiki from Japan ) and i also made a small coil windingmachine based on two steppermotors and and Atmel microcontroller . The software was written in C.
    EMC2 has all the software you need to make a machine of your own.
    A lot depends on what you intend to do. You mention filament winding. I guess carbon fibre and any other kind of fibre comes under that label.
    So may be You can tell us a bit more..say:
    Nature of fibre?
    How large a diametar do you want to process?
    Circular or irregular radius?
    Thickness of winding?
    All of this will help to discuss the filament handling and delivery mechanism to the pool or dolly.
    The reason i mention nature of filament isbecause everything else must follow on from the type of filament and winding geometry.
    Dolly or former is the base upon which the filament is wound.
    Jan 2010
    6
    Zig,
    Thanks for the answer.
    I think that will be approximately so:
    1. Fiberglass roving, 735 tex
    2. Articles as symmetric and not symmetric
    (fittings for pipelines, elbow, tee and so on, short pipes)
    3. The maximal external diameter of a symmetric detail of 300 mm
    4. Thickness the wound stratum up to 20 mm
    Mar 2008
    267
    Igor,
    Your requirement is not readily met by a "self made" machine.
    There are a number of isssues which need to be resolved at a fairly sophisticated level in order to form elbow components and non symetric elements.
    Most notably a cad/cam package which will generate the NC instructions.
    Do you already have such software solutions?
    Once the software is determined it will then be necesary to translate the axes and degrees of freedom in the software to equivalent mechanical axes and degrees of freedom.
    The delivery of filament will be through a nozzlewhich will ensure the filament is deposited at the right tension and in the correct space.
    SO again I come back to the CAD/CAM software. Do you have such a software package in mind?
    Let me just say that straight cylindrical product is not difficult to make or to write NC code .
    Jan 2010
    6
    Zig,
    To wind symmetric details, not absolutely interestingly
    At me is not present CAD \CAM
    I think what to buy CADWIND or CADFIL or other software
    I cannot, a big price
    Likely it is possible to ask to generate NC
    At those at whom is CAD \CAM
    But CAD, fiber delivery systems, tensioners, resin impregnation it is a following stage.
    Now I think about winder.
    What loadings and forces, accelerations, drives, transmissions, amount of axes and so on.
    Zig,
    I very badly know English
    I ask me to excuse
    Jun 2010
    Hello Igor,
    We are a small company and wind carbon and glass, and may be able to help you.
    We are in the Process of building our own filament winder, it is not cheap, around US$30,000 to do yourself. You will need a CAD package, CADWIND is what we recommend and can provide you with a license.
    To wind elbows and tees is hard without CAD, straight pipe is easy.
    Please see our website to find out more.
    www.etamax.com.au
    Jan 2009
    Quote Originally Posted by etamax View Post
    Hello Igor,
    Etamax Engineering - Composite Materials Engineers
    Hi Etamax
    Does Cadwind output just G-code for cnc machine?
    What input does it need to specify before this make g-code for machine?
    I mean whats input and whats output???
    Alireza
    Jun 2012
    help with cfrp winding
    Dear friends,
    I need your help in filament winding process. I was performing a R&D work with carbon fiber/ epoxy filament winding of underground storage tanks. Having attempted several times, after the first layer of 100+ passes, the fiber starts to slip due to unknown reason. I want to avoid the slippage. How can I do that? I have tried researching on the internet with many scienctific papers but solution is nowhere to be found, it could be I am looking in the wrong place.
    I would like to request experience people to advise me. Thank you.
    My email is [email protected]
  1. CNC filament winder(carbon fibre)
    By wallygator99 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 10:49 PM
  2. Filament Winder
    By RotorRouter in forum Open Source Controller Boards
    Last Post: 03-31-2014, 05:14 PM
  3. Replies: 11
    Last Post: 07-10-2010, 07:34 PM
  4. Hello from Voronezh (Russia)
    By Panvic in forum European Club House
    Last Post: 12-08-2008, 05:55 PM
  5. Travel To Russia
    By moNkaD8 in forum Australia, New Zealand Club House
    Last Post: 08-16-2006, 02:16 PM
