Hi guys: I'm looking to get into CNC. I have limited experience machining things by hand and no prior experience with CNC. I'm pretty handy with computers and electronics though.
I would like to get (or build) a benchtop CNC mill. After looking at different mills, I realized I simply don't know enough to choose one. Hence, I would appreciate some advice from folks here who are more knowledgeable than I.
What I'm looking for is accuracy above all. I would like to machine small parts accurate down to 0.001 inch in all dimensions (ideally), sometimes in very complex shapes. I don't care how long it takes, as long as the machine can run unsupervised. I don't need power such as (eg) to make heavy cuts in steel etc. I will probably work on mainly plastic and (soft) aluminum, very rarely steel. The largest part I foresee working on is roughly 8 x 2 x 2 in (and typical sizes are much smaller, 2 x 2 x 2). I'm not adverse to putting together a CNC retrofit kit on a non-CNC machine, or wiring my own controller/steppers/electronics. I'm not looking necessarily for something that works out of the box, but I would prefer to not have to make my own (eg) motor mounts, or have to modify castings, polish ways, etc etc. I would like to keep this under a $2k budget (excluding tooling).
So far, I have looked at: Sherline 5400-CNC, Taig 2019CR-ER, Sieg X1/X2/X3 (micromill/minimill) with respective cncfusion kits (there is a HF store right next door to me), possibly Rong Fu round column with some kind of kit (?). For the CNC part I'm looking at kits by Keling, either the G540 + 3 steppers, or 3 G320X + 3 servos. The software will be EMC. There are a few factory-built CNC machines I looked at too: Taig 2027ER, LittleMachineShop 3501/3503, MaxNC 5/10/15, ServoImpact, Prazi (used), etc, but most of those are way out of my price range. I've seen decent deals on a used CNC Sherline, maybe ~$1000 (with steppers and controller); haven't really seen the same for a Taig.
My impressions so far are that anything bigger than the Sherline/Taig/X1 is probably more power than I actually need (for now, anyway and that retrofitting an X1/X2/X3 is probably somewhat challenging from someone with no prior experience.
What I *don't* know is how does the accuracy of the smaller mills compare to the larger mills? How does (eg) a Taig compare to an X3 out of the box? How bad is the backlash on each of these (I'm guessing this would be the main source of error for what I'll be doing), and how hard is it to eliminate? (and how do I eliminate it anyway?) Do I *need* servos? (or can I run steppers at a low speed and *never* skip steps in a long program?).
So, what do you all think? Get a Taig, put servos on it and call it done? Play with an X3 refit? Something else?
Thanks!
MLG
