Can anyone please post a wiring diagram for the newer SX3 motor control with daughter board? Can you explain how to hook up a Cnc4pc C6 speed control board in the SX3? P1? P2?
CR.
CR.
Hi, here is a copy of the Super X3 controller board circuit diagram. I hope this helps.
Alex
Interesting... Do you know the origin of the diagram?
Well, it is a long story. I intially had some of the earlier Panel and Controller board set which I was trying to get the circuit diagrams for after they got destroyed through a short on the venier depth gauge. I email Sieg in China and the response was that they had no circuit diagrams.
After I received the new set of boards (updated versions) I found that the front panel was displaying an error message. I then emailed them again, and in received the circuit diagram with the necessary procedure to remove the message.
I have found that Sieg are very helpful in helping resolve any issues directly.
Alex
Thanks for posting it. It looks like the controller is based on a socketed Atmega8 processor. This makes it very suitable for software modification.
If you have the software, and if the chip is not read protected.
Probably the only option WE have is to start from scratch. At least it could start to work in a properly defined manner.
Alex.
Please spread the word. More input=more (read quicker success)
I am trying...
http://www.cnczone.com/forums/showthread.php?t=59118
When we can solid tap, (and I mean solid) it is fixed. That's the target but I need all the circuit fragments etc every one has to make the job manageable.
Neil
Would it be possible to control this motor directly with PWM from a Smooth Stepper? Would this still need firmware mods?
http://warp9td.com/documentation/Smo...ManualV1.0.pdf
CR.
It won't work any better.
The problem is in the motor control PCB.
The break out board already creates a suitable control signal from the PWM signal from Mach3.
The stupid firmware/hardware just pushes the front panel buttons like a human, trying to go faster, sh1t. too fast. slower, oops. I'm drunk, I forgot which way to go etc.
When the PWM signal goes to zero and says, stop, it can't even push the stop button, (which is ignored if it is accelerating.)
The software engineer was a moron and should not be allowed to touch this type of product.
IT IS A SAFETY ISSUE
Hi Adel
It looks like I have the same issue as you with the error with the new Boards
What did you actually do to fix the error?
Cheers
Rob
