587,997 active members*
2,099 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > One shot oiler failed - NM200
    Dec 2009
    594
    Question One shot oiler failed - NM200
    After 7+ years of service a plastic part on the bottom of my Fheng one shot oiler failed. I am assuming that a replacement part is not in the cards and that I'll need to replace the entire oiler.
    I've seen this one that looks almost identical. https://www.kbctools.com/products/FL...OIRS/3287.aspx
    What are the Torus machines being supplied with?
    Jun 2013
    1041
    Re: One shot oiler failed - NM200
    Could you make the part of you had access to a handy dandy cnc mill? 😉
    Ben
    Sent from my HTC6525LVW using Tapatalk
    Aug 2007
    359
    It's been a few years, but mine came with the push style pump. I'm pretty sure they still come with the same style.
    https://www.kbctools.com/default.asp...48&parent=7225
    Don't have to be too bright to be me
    Dec 2009
    594
    John has one in stock that I will have shipped on Monday, hopefully. More expensive than KBC but known to be a bolt on replacement for the old one.
    The part that broke is a plastic piece that screws onto the bottom of the metal body. Two ears support a roll pin on which the lever rotates. One of the ears snapped off. It would certainly be possible to make a replacement in aluminum if it were worth my time and if the mill were to remain lubricated during the machining.
    Dec 2009
    594
    Got the new oiler today. Looks identical to the old but one of the 4 mounting holes doesn't quite line up. I wonder if they drilled out one of the tabs on the old one. Seems three screws are enough to keep it attached. I needed to swap the brass elbows with the old pump as the threads are different. Looks like 1/8 NPT on the new and 1/16 on the old. Filled it up and seems I'm back in action tomorrow.
  1. ONE SHOT OILER MODIFICATION
    By JTJT in forum Shopmaster/Shoptask
    Last Post: 04-03-2017, 02:58 PM
  2. Preferred oil in one shot oiler?
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 10-31-2013, 06:22 PM
  3. One shot oiler question
    By g29cc in forum Novakon
    Last Post: 09-09-2010, 04:09 PM
  4. One-shot Oiler Question
    By rowbare in forum Tormach Personal CNC Mill
    Last Post: 09-07-2010, 04:12 PM
  5. One shot oiler
    By Bubba in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2009, 03:39 AM
