Hello Syil China and those who may able to help me.
I have just received my new X6, with Delta VFD-M Control and Pneumatic Draw Bar System... etc.
But here 's the problem, we have found out that the lower limit sensor of Z axis is not working, I mean even I press the sensor, there are NO pin showing active, can Syil please show me the wireing diagram and pin number for this?
Another problem we have is that we can not control the VFD in Mach3, actually, we can only control the spindle by the dial on the front of the machine.
We also did not find any indication on the control of the Pneumatic Draw Bar System in X6 manual, I mean we need instruction in paper about how to set up Pneumatic Draw Bar System with Mach3.
A suggestion I would like to make is that Limit switch in China is cheap, for the X and Y axis, please put the limit switch on BOTH sides of tail, not just stopper on the both end, and only ONE limit switch in the middle. It is impossible for the machine to know it's possition when the machine just power up and one of the limit switch is active.
Another mind bothering problem is that there are no clear instruction about the setting in Ports&Pins menu, I would like to ask Syil, please show us how to config, Motor Outputs, Input Signals, Output Signals, and Spindle Setup menu.
Let me make the above in short words and in Chinese, and hopefully Syil will able to help me and make me a happy customer:
1. Z axis lower limit is disconnected, please show us connection diagram.
Z軸的下限開關沒有接好,請提供接線圖。
2. Mach3 can NOT control VFD controller (as per CNC X6 Instruction manual of Pin2 for spindle pulse and pin 1 for spindle direction) to control spindle speed and direction.
Mach3 無法控制VFD控制器 (我們照CNC X6 說明書上所說的設定Pin2為主軸速度與Pin1為主軸方向) 請給明確說明如何讓Mach3控制VFD
3. Can not find any control for Pneumatic Draw Bar System with Mach3, please show diagram
我們找不到關於氣壓換刀系統的控制,請解釋於Mach3下要如何控制。
Thank you for your prompt reply in advance,
Cheers
Shenta
[email protected]
