588,616 active members*
5,251 visitors online*
Results 1 to 6 of 6
    Dec 2010
    tapping cycle
    my controller is fanuc 0i,cnc lathe.and i want to know about ragid tapping cycle.
    2932
    I believe that some builders include the option of Canned Cycles for Drilling (G80-G89) with their machines, others don't. If your machine has live tooling, it may or may not have Rigid Tapping. So it might help to know what machine make and model you have.
    If it has Rigid Tapping, M29 is usually used to activate the Rigid Tapping. So to program a tapped hole on the main spindle, it might look like this:
    N3 G28 U0 W0
    T0303 (M6X1 TAP)
    G00 G97 X0 Z3. M08
    M29 S200 (ACTIVATE RIGID TAP)
    G84 Z-20. F1. (TAP 20MM DEEP)
    G80 M09
    G28 U0 W0
    M01
    Aug 2009
    684
    I'm the expert on ragged tapping
    DP
    Mar 2005
    816
    I've never done that many tapped holes on the lathe... a lot of OD threads but not much internal threading or tapping.
    On the mill I use a CAT40 Bilz style T&C head with the Bilz tap collets. On the lathe I do OD laydown threading with some Carmex inserts (though I've heard that Kennametal, SECO and ToolFlo have good ones).
    I have a pretty well configured 0T-C at my disposal and I'm still learning lathes using this particular control.
    I admit I haven't been using the canned cycles as I probably could be, but I was given some examples to try out. Anyone wanna try sending me some examples for my OT-C to try out?
    I've recently seen a lot of neat mill/turn centers doing some drilling, tapping and threading.
    Dec 2010
    thanks sir ,i will try,
    Dec 2010
    ok,thanks,i will try it.
  1. TAPPING CYCLE G84
    By Mori in forum G-Code Programing
    Last Post: 03-26-2022, 12:11 AM
  2. G84 & G74 tapping cycle
    By Karl_T in forum G-Code Programing
    Last Post: 04-21-2013, 04:48 AM
  3. Fanuc 6T-B tapping cycle?
    By party o one in forum Fanuc
    Last Post: 09-19-2008, 05:20 PM
  4. Coolant M7/M8, Tapping Cycle 207
    By cutteredge in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2008, 11:12 PM
  5. Correct tapping cycle???
    By Karl in forum G-Code Programing
    Last Post: 05-31-2004, 10:37 PM
