588,235 active members*
4,323 visitors online*
Results 1 to 13 of 13
    Mar 2015
    12
    Sinumerik 810M GA 1 - memory expansion
    Hello,
    I purchased a Chiron and doesn't have enough space for programs.
    Chiron details:
    FZ12W 107-71 ,
    Sinumerik 810M GA 1, 6FC3471-1AA-Z
    I want a solution for memory expansion or if possible a communication program Sinumerik PC in real time.
    Thank you.
    Razvan Radu,
    [email protected]
    www.qraglobal.ro
    Attached Thumbnails Attached Thumbnails IMAG0641.jpg   IMAG0654.jpg   IMAG0655.jpg
    Mar 2010
    1852
    Re: Sinumerik 810M GA 1 - memory expansion
    Do you mean there is not enough memory for "A" program or "All" of your programs? I have an 810T and had a similar issue with not having enough memory even after clearing programs. It turns out that the memory that is cleared is not necessarily available to be used again until reorganized.
    Below is a page from my manual and it worked fine for me.
    Mike
    Mar 2010
    1852
    Hello, anyone home?
    Mike
    Mar 2015
    12
    Hy,
    Thank you for your answer and sorry for my late reply.
    I've already done what you said. The problem is that the program storage capacity is too small 15000 and I need it to be somewhere around 300000 - 500000. The programs we use are quite large.
    Thank you.
    Razvan Radu,
    [email protected]
    SC QRA GLOBAL SRL - Prelucrari mecanice
    Mar 2010
    1852
    You did not say, but you must have that control on a mill, as you would never need that much memory on a lathe.
    I think you are out of luck with that old control.
    Mike
    Mar 2015
    12
    I'm not sure that I understand what you want to say with "you must have that control on a mill"?
    Mar 2010
    1852
    What I meant was that lathe programs aren't very large. Mill programs are much longer/larger because of what they do, using small segments and moves etc.
    What is the control on then?
    My 810T is on a lathe. I have only about 7500 charterers in mine and with 10 programs saved in there, I still have 2/3rds of my memory open.
    Mike
    Mar 2015
    12
    Mike do you write and imput your machining programs manual or are generated by CAD-CAM software? I write and imput machining programs manual. A program has 200000 charterers so it cannot be generated by CAD-CAM software.
    Hope yor understand what I'm trying to say.
    Thank you.
    Mar 2010
    1852
    I do both, hand and CadCam. You still have not said what type of machine you have. How is it possible that your CAD system can't write that large of a program? I do know that there is no way I would stand in front of my 810T and input a 200000 character long program, it would be nearly impossible to do.
    Mike
    Mar 2015
    12
    Hy Mike,
    I have a CHIRON FZ12W Vertical Machining Centre. Can you tell me what software do you use?
    Mar 2010
    1852
    BobCad V-23.
    M
    May 2014
    18
    I have the same machine (and software) and also VERY interested if someone can/will give an answer to the question, how do I get more memory space?
    I found out at the time the machine was sold there was an option 48K available (and there is an option 32K ram module in the GA1 installation book from siemens) but that doesn't seem to be available anymore (not even on Ebay)
    The number for this module should be 6FX-1123-0BL...
    I hope someone can give an answer to this question, and reorganising the memory doesn't help me (I have 12375 free space)
    gr
    Bart
    Jul 2013
    4
    Thanks for your input, Radu!
    _______________________
    Steve Works
    confectii metalice
  1. Siemens Sinumerik 810M document set
    By fahrphrompuken in forum Machinery Manuals / Brochures
    Last Post: 06-21-2024, 07:48 PM
  2. Famup FCN 500 Sinumerik 810M parameters
    By guhl in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-11-2018, 02:51 PM
  3. sinumerik 810M error #12 - PP memory wrong format
    By vavco in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 11-18-2012, 01:18 PM
  4. SINUMERIK 810M - 7024 error
    By rliovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-23-2011, 04:20 PM
  5. SINUMERIK 810M GA1
    By amo in forum CNC Machine Related Electronics
    Last Post: 11-17-2009, 09:58 AM
