588,201 active members*
5,120 visitors online*
    Apr 2008
    123
    Question rotary engrave ???
    Hi guys,
    Can I engrave around the edge of a diameter using conversational on
    a Hurco VSX24 using a 4th 'A' axis and with Ultimaxx ssm control?
    I cant see how to do it.
    Would I be better using edgecam ??
    Thanks for any help guys.
    Apr 2008
    123
    Can anyone point me in the right direction here guys?
    Nov 2006
    382
    You can do it. It is a little cumbersom. Hopefully I can keep it simple. Here goes.
    do a letter like you are trying to put it in the 12 o'clock position. Then copy the block for however many letters you have then use pattern rotate before the second letter and rotate the second letter 10 or 15 degrees. Then after the letter do a pattern end. You have to look and adjust each letter. For example W and I take up different spaces in the lettering and require a different gap. So W may need to rotate 12 degrees and I only 8 to look the same as two O's side by side. This should do it, if not pm me and I will try to explain more or in a better way. Hope that helps. I also do training on the Hurco controls if needed. Jetski
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
    Apr 2008
    123
    Smile
    thanks jetski,
    I appreciate your answer, yes i understand what your saying and it will work Im sure.
    I will use your method and give you some feedback.
    Cheers
    Apr 2008
    123
    Quote Originally Posted by jetski View Post
    Hi Jetski..
    It did work of a fashion.. the leter spacing was less than perfect and the overall look was'nt that great BUT it did the job.
    Thanks for your input. :-)
  1. locamotive engrave
    By woodman08 in forum LOGILASE Laser
    Last Post: 03-29-2010, 01:07 AM
  2. how to engrave
    By cob in forum Mastercam
    Last Post: 10-17-2008, 08:51 PM
  3. How to engrave pcb with laser
    By codes in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2008, 09:23 PM
  4. How do I engrave numbers...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 08:35 PM
