When loading a G code it seems to stall out while its loading it. When I try to load it again it works fine.
Is this a sign of mach 3 didn't load correctly?? And yes I restarted the computer immediately after loading mach 3.
Second thing is: When I start up my machine I have a E-stop triggered warning even if the e stop is released.
Here's how I start it up.
Start up mach 3 once running, Turn on the main power to my electrical cabinet (this powers up my power supply and G540) Then I release the e-stop button and reset the button in mach 3.
After that I get the e stop triggered again. If I look at my diagnostics page the only input mach 3 is seeing is my E-stop. Now if I go to ports and pins and flip the active low switch it will work for say 30 seconds and then work opposite of what I want so I toggle the active low setting again and everything starts working as normal.
So is this just the charge pump warming up to say? Is there a debounce level for that? Is it normal?
