588,478 active members*
4,938 visitors online*
Results 1 to 9 of 9
    May 2003
    267
    Cheap coolant system
    I was thinking of using this submersable pump designed to be used for cutting tile or for water fountains as a cheap way to add coolant while milling metal/aluminum stuff. It cost about $7.50. Instead of using coolant fluid, I was thinking of just using clean water from my garden hose (or maybe I can add coolant fluid later). Basically, just submerse this item under water and attach a plastic tube where the water must exit out of. In my theory, it could work. Any suggestions?
    See submersable pump at:
    http://www.harborfreight.com/cpi/cta...emnumber=45305
    24221
    George, That all I am using right now with water soluble coolant, for that price you can replace every year if you have to. I wrapped mine in a fine mesh for filtering out any swarf.
    Al
    Jul 2003
    14
    Yes. This method works great and very inexpensive.
    We run a $29.00 fountain pump on a 48x60 Boring mill.
    May 2003
    267
    Al_th_man,
    What kind of filter (fine mesh) do you use and where can I get one? How can I make my own filter? What kind of coolant works with these pumps?
    Oct 2003
    927
    George: clear water
    Above you mentioned using just clear water...don't do it! Part of the reason for "coolant" is to inhibit rust...
    For coolants, in my case, I'm going with ENCO's SYN-KOOL. It's advertised as able to withstand intermitant use without spoiling over time....
    Jul 2003
    125
    Depending on what you're doing, you might also consider using air pressure to force coolant out of a closed tank. I've seen this done with small aquarium air pumps as it allows finer control over the coolant output without the overheating that some liquid pumps experience when the flow is too low.
    24221
    George, I just used a fine muslin cloth, It used to be known as 'Mutton Cloth' You be able to find small bags made with a draw string thats ideal, Home brewers also use these bags for hanging hops in the brew. The coolant is a generic oil based, water soluble type that is common mixed from 5:1 to 100:1.
    Also, do not worry about restricting the flow with an inline tap as impeller type pumps actually decrease in load the higher the restriction.
    Al
    Albert E.
    Oct 2003
    927
    another option is to install a variable bypass valve to allow the pump to circulate higher volume yet still supply a "trickle" to the work if needed. This in addition to the nozzle control valve.
    Jan 2004
    83
    Bloy is absolutely right, dont think about using any kind of water by itself. Coolants have rust inhibitives which prevent oxidation of metals, which is crucial, obviously.
    Just keep that in mind, hope it helps.
    H3ndrix
  1. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  2. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
  3. coolant system
    By mtechserv in forum MetalWork Discussion
    Last Post: 03-27-2005, 07:09 PM
  4. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
  5. Need suggestions on components 5 axis control system?
    By pab in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2005, 11:34 PM
