Originally Posted by
mocnc
maybe I didn't make myself too clear....I need help in choosing my initial programs to get started with my cnc. Programs like.........
AutoCad ------------> what is out there that is ok and free or cheap for start up
Cam ----------------> any programs for this? (I have a 4axis easycnc board)
Program to genterate g-codes
Program to convert pictures (jpg/jpeg, giff, bitmap etc.) to gcodes.
Any help would be great....being somewhat a newbie its sometimes hard to determind what is what is the best way to go. But with help from others who have gone thru the growing pains will make it easier to start. I know I can't be the only one with this question....there has to be more out there that have the same thoughts....maybe not on all programs but on one or two of them. Once again thanks in advance!
Cad program. Viacad is $69 for the 2d and $99 for the 3d.
Cam programs generate the G-code. A good all around program that I use for my cam needs is Deskcnc.
It will also run your machine if you buy the interface board. I liked it for my router because one program will run the machine and write the G-code.
It imports dxf's and outputs G-code. It will also import stl files for 3d work. On top of that it accepts several image formats for engraving and converting to G-code.
You can download a working trial from www.Deskcnc.com
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
