587,214 active members*
3,403 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Teco 7200MA VFD settings Help
Page 1 of 2 12
Results 1 to 20 of 23
    Jan 2019
    8
    I have a Teco 7200MA VFD 240v 50/60hz. HP: 3 KVA: 4. output 3ph 240v 9.6amp
    the original spindle motor has died, I have decided to replace it with a water cooled spindle.
    I have bought a Jianken JDG 80/2.2kw 220v 400hz 6A water cooled spindle
    these are the VFD parameters sent with it
    power: 2.2kw
    max speed: 24000rpm
    upper limit of the frequency: 400HZ
    rated frequency: 400HZ
    time of speed up / down: 20~30s
    need help with the setup parameters any help would be greatly appreciated.
    I have the user manual for the VFD but find it very confusing I would like to get it right first time rather than damage the spindle or VFD
    15362
    Re: Teco 7200MA VFD settings Help
    Quote Originally Posted by JohnTC View Post
    power: 2.2kw
    max speed: 24000rpm
    Can you post a PDF of the manual I have some Teco VFD drive manuals but not that one yes you need more than just those parameters
    Mactec54
    Jan 2019
    8
    here it is. thanks for taking time to help
    15362
    This should get you going there may be some other Parameters to adjust or set
    Teco 2.2Kw 400Hz 24000 RPM Spindle
    BN-01=6 ( Acceleration Adjustable )
    Bn-02=8 ( Deceleration Adjustable )
    CN-02=400
    CN-03=220
    CN-04=400
    CN-05=200
    CN-06=110
    CN-07=120
    CN-08=66
    CN-09=8
    CN-10=50
    CN-19=30
    CN-25=110
    CN-26=110
    CN-34=4 ( Adjust up to 6 )
    CN-45=2400
    CN-46=02
    SN-66=1 ( Auto Tune after all Parameters are set )
    Mactec54
    Jan 2019
    8
    Many Thanks Mactec54
    Jan 2019
    8
    Im getting an PG parameter Error with the above settings
    "Quote from manual"
    Cn-45 and Cn-46 must meet the following relationship:
    2 * Cn-45 * Cn-02 / Cn-46
    ?If not, an error message “Input Error” will be displayed
    Help
    ericks Guest
    Your error is due to incorrect parameters.....the calculation the drive made with the parameters you were given is causing this error
    Jan 2019
    8
    thx for reply. yes I realise that. its the Cn-45 parameter that's the problem.
    15362
    "Quote from manual"
    Help
    That's the spindle RPM
    The CN46=2 for your 2 Pole motor
    CN02=400 which is correct
    So CN-46 has to match the spindle RPM 24000 I'm not sure if it can accept 24000
    So CN-46=24000 Not 2400 should correct this
    Mactec54
    15362
    Quote Originally Posted by ericks View Post
    The parameters are correct unless you know better:wave:
    CN-2=400
    CN-46=2 number of Poles
    CN-45=24000 spindle speed
    CN-45=2400 missing a 0
    Mactec54
    Sep 2005
    1740
    CN-2=400
    Yes you posted it wrong
    Jan 2019
    8
    well I have a problem. the Cn-45 parameter range is 0000.1 ~ 3000.0 P/R. is there a work around.
    Sep 2005
    1740
    He has given you the wrong parameter to set, Like I said earlier, instead just asking someone on the internet get the correct answers from either the dealer or the maker.
    15362
    Quote Originally Posted by wmgeorge View Post
    Can you solve the problem the parameters are correct as per the manual
    Mactec54
    15362
    Set it at the default of CN-45=0.0 and see what it does
    Mactec54
    Jan 2019
    8
    I have contacted the makers first before posting and they haven't got back to me
    Cn-45 parameter looks to be for encoder counts per revolution, I maybe wrong still learning
    Sep 2005
    1740
    Is that what the book tells you? Looks as if its set up to give feedback for a rpm indicator.... If so that should be turned off. When I set up my Hitachi drive I only needed to change maybe 4 or 5 parameters, the rest I left at default. I just read through the manual to see which ones to change.
    15362
    That's all you can come up with, read what I posted, ( This should get you going there may be some other Parameters to adjust or set ) (nuts)
    - - - Updated - - -
    Mactec54
    Sep 2005
    1740
    Out of the PDF
    (39) PG Parameter (Cn-45)
    ?The parameter is set in the unit of pulse/revolution. The factory setting is 0.1 P/R.
    (40) Pole Number of Motor (Cn-46)
    ?Cn-45 and Cn-46 must meet the following relationship:
    2 * Cn-45 * Cn-02
    Cn-46
    < 32767
    So Cn46 should be set at number of poles which is 2 try that. I did the calculation and it comes out 40 which is
    < 32757
    The factory setting for Cn45 should be 0.1
    Cn 02 is Max Freq
    Other than that, call the dealer in the morning and get the settings they want changed.
    15362
    Out of the PDF
    2 * Cn-45 * Cn-02
    Cn-46
    < 32767
    < 32757
    Cn 02 is Max Freq
    The factory setting for CN-45=0.0 not 0.1
    CN-45 should be set to 0.0 he is not doing anything with that parameter if you set this Parameter you have to set other Parameters related to it
    He already has CN-46 =2 and CN-02=400 check the Parameter list I posted
    Mactec54
Page 1 of 2 12
  1. Teco JNEV-101-H1 help
    By Blakea1790 in forum Benchtop Machines
    Last Post: 12-18-2014, 03:19 PM
  2. Any one works with TECO?
    By ssureshtronics in forum Servo Motors / Drives
    Last Post: 06-06-2011, 12:51 PM
  3. -Need help with Teco vfd on bridgeport
    By cruzin in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2010, 01:39 PM
  4. Problema con Teco FM 100
    By poxipaul in forum Spanish
    Last Post: 11-20-2007, 05:01 AM
  5. TECO FM100 Help?!?!
    By Ben Colby in forum Phase Converters
    Last Post: 05-29-2007, 06:51 AM
