588,017 active members*
8,549 visitors online*
Thread: pistol grips
    Aug 2008
    pistol grips
    I want to duplicate the grips on my pistol in wood. I will need to do 2 side mashining as there are reliefs on the back. Will Meshcam Art allow me to scan the grips and convert to 3D for carving
    Apr 2003
    178
    With either version of MeshCAM, you an take the 3D file of your scans and generate toolpath to cut it out. However, neither will do the scan for you or generate a 3D surface from the point cloud data.
    I generally recommend the David scanner if you want a minimum-cost scanner or the Nextengine scanner if you have a little more money to spend.
    Let me know if I can answer anything else for you.
    -Robert
  1. getting to grips witha HY-TB3DV-M driver board
    By orchardtim in forum Maintenance DIY Discussion
    Last Post: 03-06-2011, 12:01 AM
  2. Custom pistol grips [Beech or Walnut].
    By Need CNC in forum Employment Opportunity
    Last Post: 06-03-2009, 02:27 AM
  3. .22 caliber pistol
    By Bigbull in forum Hobby Discussion
    Last Post: 12-09-2008, 09:57 PM
  4. Pistol grips 1911 Kimber
    By Revtech in forum Uncategorised CAM Discussion
    Last Post: 02-01-2007, 03:29 AM
