588,398 active members*
4,351 visitors online*
    Feb 2008
    Easy-path lathe
    Need help with G P fault-fatal error on bridgeport easy-path lathe. The software will try to restart. To clear the error it must be in MDI. The system will try to save the current work. Then gives a "possible pointer error." Got any ideas?
    gcarter
    Dec 2007
    Have you tried to reboot cletus?
    Mar 2009
    at cold start I get a emergency stop zfault as follows error #1 motor overload
    I tested voltage at slot 11z 9x and 10 y they are al ok at 1.7 volts. can anyone help me
    Oct 2009
    16
    I know this is an old thread but did you ever come across the fix?
    I am having the same problem on my Bridgeport/Romi ezpath lathe.
    I get the GP fault - fatal error which is followed by a
    system error- possible floating point error
    Then then the machine locks up.... i restart the machine sometimes it will run for a short time then i will get the GP fault and the system error again
    Any help
    Brian
    Oct 2009
    16
    fix
    Just thought i would post the fix
    Had an tech come to look at it and right away checked the mother board and found it had become a little lose, pushed it up and into place and the lathe is now running perfect!! He told me this is a common problem with these bridgeport machines. He says lot of ppl misdiagnose it as a bad motherboard and replace the board.
    Now building parts again and it feels good!!
    If anyone is in the South Western Ontario (Windsor area) and needs electrical help I know a great tech!
  1. Bridgeport/ROMI EZ Path Lathe
    By mcsf in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2012, 12:39 AM
  2. Ez-path Lathe
    By harley88 in forum DNC Problems and Solutions
    Last Post: 05-26-2008, 07:55 AM
  3. easy path s computer
    By danl in forum Bridgeport / Hardinge Mills
    Last Post: 07-01-2007, 09:23 PM
  4. EZ Path Bridgeport lathe
    By ruger2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-31-2007, 07:33 PM
  5. Romi EZ Path Lathe
    By kenski in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2006, 03:25 AM
