588,621 active members*
5,447 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How do we remove the Way Covers for the Y axis on a VMC15 + Spindle Oiler Location?
    Jul 2006
    741
    Hi all,
    So, I removed the 3 bolts towards by the bottom of the Z axis, the two side covers and the small front panel from where I suppose the "box" slides out. The cover is firmly in place, no signs of giving at all. Perhaps the next step is to remove the wipes attached to the saddle? Am I missing something? How do we get it out. Judging by what I found in the Z and X axis there is probably a quite a bit swarf in there.
    Also, the manual says to check the oiler levels for the ways and spindle. This a linear guides machine so I presume there is no oiler for the way, but I can not find the olier for the spindle or any reservoir for fluids at all. Is that right?
    How do you lubricate the linear guides. I just greased the rails themselves. Is that sufficient?
    Thanks!!
    Nov 2003
    287
    Re: How do we remove the Way Covers for the Y axis on a VMC15 + Spindle Oiler Locatio
    Most have a lube pump located under the electrical panel with the big power transformer. The pump should have an air line from manifold and also a plastic lube line. To remove the Y axis way cover there is i believe 2 bolts on the bottom side of cover, near front doors. You also have to remove small panel on front of machine, this allows way cover to slide out front.
    Jul 2006
    741
    Thanks the 2 bolts towards the front were covered by gunk and I did not see them in the diagrams. All cleaned up now, waiting for the grease to arrive. Thanks!!
    Under that panel the only thing I have are 2 solenoids and air lines. There are no other connections/tubing. May be it is a sealed spindle? It is a 94 machine with a 7500 RPM motor. How can I make sure?
    Jan 2015
    417
    fadal 7500 rpm spindles are all grease packed they have no fittings to regrease. And go to Flintmachine.com and download any of the Fadal manuals for free. heres the link for the vmc 15 Very very usefuld lots of detailed info.
    http://www.flintmachine.com/pdfs/fad...MC_15_15XT.pdf
    Jul 2006
    741
    Great! Thanks.
  1. Replies: 22
    Last Post: 05-11-2015, 03:52 PM
  2. Fadal VMC15 CNC88 spindle issues
    By DMCRacing in forum Fadal
    Last Post: 08-05-2013, 12:45 PM
  3. VMC15 spindle speed problem - commands
    By FastFieros in forum Fadal
    Last Post: 02-12-2008, 11:54 PM
  4. Fadal VMC15 servo & spindle problems
    By FinnCNC in forum Fadal
    Last Post: 04-18-2007, 04:03 PM
  5. How to remove way covers?
    By damae in forum Bridgeport / Hardinge Mills
    Last Post: 01-09-2006, 10:50 PM
