i am planning to buy my first cnc lathe benchtop type...
i need a cnc lathe which is capable of threading on steel...
can any1 help me or link me to one?
Thank you in advance.
I put stepper motors and Gecko drives on my 7x14 Mini lathe and
bought the Autoturn lathe controller which lets you cut threads
and more.
I don't think there is a complete solution. You have to decide what
size of machine and for what purpose you need it for plus what
operating system you want and then run a search on the net. It is
of course very important how much you want spend on your ideal setup.
Thank you...
i was looking at the D3CNC.com....
but, its a bit pricy...it does the job tho....
something similar if i can get in a bit lower price, than it will be great....
sherline cnc lathe does not support threading....
is there any1 else with the above type/size/price of machines?
I think that the Wabeco CNC lathes do threading, but they are a lot more expensive than the typical 7x10 or 8x14 lathes.
FWIW, I have a 7x10 lathe on a CNC mill table that will do threading (the Tormach system) but the 1/4 HP lathe motor crapped out the one time I tried to thread 6061 aluminum at 2 or 3 thou per pass so you might have problems threading steel.
Mike
how about this one from Novakon:
http://www.novakon.net/3.html
any1 using it?
I'm looking for the same little lathe.
The one u mentioned down below looks like a Harbor freight lathe that they modified. (I don't know)
BC v21 is a few years old now, BC v23 has been around for about a year now?
Supposed Flashcut CNC has a system using a Sherline lathe which will cut threads...
I spoke to someone today and they were actually recommending EMC(Linux based) for a CNC lathe for cutting threads over Mach3. But they prefer Mach3 for mills...Supposedly EMC can use encoders while Mach3 really doesn't. They just have a program that stops the machine if the encoder and postions don't match up...
Did that make any sense?
