588,004 active members*
3,503 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Problem with surface rough...
    Nov 2005
    164
    Im finally doing some more complicated machining other then 2 axis stuff and my knowledge is limited. Im trying to make a simple die that will shape the end of a tube. Im doing a surface rough using a 1/2" ball em but for some reason it wants to make the first cut the depth of the tool radius (.25") when I want all cuts to be only .05". I have checked all of the settings and cant find anywhere to change it. I have attached 2 screen shots, you can see the first tool path at the top of the parts is much deeper then the rest. Any help would be greatly appreciated.
    Jim
    BTW im using MCAM X the first version.....
    I,m guessing rough pocket? go to the cut depths button and it will say adustment to first cut change this to .250 or check the box that says adjust top cut to depth cut. this will do it. if not send me the file.
    steve
    www.cad2cam.net
    [email protected]
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Jun 2005
    305
    Try using ABSOLUTE depth cuts rather than INCREMENTAL.
    Also try using "Roll tool over all edges" rather than "Automatically".
    This is located under the parameters tab, advanced settings button.
    Attached is a REALLY simple example in MC9 format.
    Attached Files Attached Files
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Jim,
    Sorry I just read the thread again you have center of the cutter selected not the tip of the cutter, you need tip selected if not it will adjust the cut to the center of the cutter -.25 in this case.
    Steve
    [email protected]
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Nov 2005
    164
    Thanks for the all the help guys......think that did the trick.
    Jim
  1. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  2. machining angle for surface rough pocket for MC9
    By Chuck Reamer in forum Mastercam
    Last Post: 08-31-2007, 12:39 PM
  3. Rough paralel surface does not work
    By cijunet in forum Mastercam
    Last Post: 03-03-2007, 11:28 PM
  4. Swept Surface problem
    Last Post: 02-18-2007, 04:34 AM
  5. 3D Milling Surface Finish Problem
    By TurboME in forum MetalWork Discussion
    Last Post: 12-18-2006, 05:32 AM
