588,633 active members*
5,515 visitors online*
    Jun 2008
    Unhappy Swapping an axis
    My Galil DMC1846 card has developed a fault with the 2nd(Y) axis.
    Is it possible to tell CamSoft Pro to use the spare unused (A) axis on my card to become the Y axis so that I can carry on using my machine?
    Greg
    24222
    If you have 4th axis there should be no problem.
    You have to swing the encoder over etc.
    Make sure it is not a encoder problem or damaged cable that caused the Y axis problem in the first place?
    Al.
    Albert E.
    Mar 2004
    1543
    Hardware - no problem.
    Software - I don't know of a way to swap the y with the a axis easily. It would take a lot of rewrite and commands like G2 and G3 might give real trouble.
    I'd ask the experts at Camsoft, maybe there's a way to swap the definition of the fourth axis from a to y. I'd like to know the answer.
    Karl
  1. Swapping the a card driver to x
    By duckslayer in forum Haas Mills
    Last Post: 09-06-2018, 05:26 PM
  2. Swapping vector drives
    By 6inall in forum Fadal
    Last Post: 05-31-2012, 07:49 PM
  3. Swapping M3 and M4 in Fanuc 10T???
    By Andy Fritz in forum Fanuc
    Last Post: 01-25-2010, 06:20 PM
  4. Swapping out the 3 phase motor
    By fireguy976 in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2009, 04:04 AM
  5. swapping bearings?????
    By the4thseal in forum DIY CNC Router Table Machines
    Last Post: 12-13-2007, 02:20 AM
