588,653 active members*
7,081 visitors online*
    May 2009
    29
    Question Aggregate heads
    I've never toolpathed with aggregate heads before and I am not sure how to go about it in MasterCAM X5.
    How would I set-up the head in MX5, and how would I make a toolpath with it?
    Also, how would I measure the tool?
    Our machine only does 3 axis normally and we just bring the tool down to the table and stop when it touches a bit of paper underneath.
    May 2004
    4519
    Try using your planes. I do not know if there is any need to set up a head as a separate tool. Just select the cutter needed from your tool library. I did a test on X3 and it seemed to work as i expected it to.
  1. anybody built an aggregate head?
    By Boltz in forum DIY CNC Router Table Machines
    Last Post: 07-26-2012, 10:55 PM
  2. setting up an aggregate head in mastercam
    By renglish in forum Mastercam
    Last Post: 05-02-2010, 06:05 PM
  3. SCM Record 220 Aggregate Help
    By danpd13 in forum CNC Machining Centers
    Last Post: 06-21-2009, 08:06 AM
  4. Greybeard's Epoxy/Aggregate cnc router
    By greybeard in forum DIY CNC Router Table Machines
    Last Post: 07-17-2008, 10:00 PM
  5. Aggregate Head With Thread Mill
    Last Post: 01-27-2007, 12:57 PM
