I have run across an issue here and I don't want to blow it literally or otherwise.
My motor diagram shows windings A and C are connected and then B and D are. I did verify with the ohm meter.
The PDF from Gecko states this.
(TERM. 3) PHASE A Connect one motor winding to this terminal
(TERM. 4) PHASE B Connect the other end of the winding to this terminal
(TERM. 5) PHASE C Connect the other motor winding to this terminal
(TERM. 6) PHASE D Connect the other end of the winding to this terminal
Connect one motor winding to terminals 3 and 4. Connect the other winding to terminals 5 and 6.
There is a labeling conflict here. Shouldn't I wire them AC BD? This would jive with the motor phases in my case and the last statement in the PDF. Thanks for any help on this. Getting this wrong could cost me.
Here is the
link to the schematic.
