588,603 active members*
9,114 visitors online*
    Jun 2005
    84
    Pierce 1/2” SS with PM1250
    I have been trying to cut some 1/2" holes in 1/2"SS. I am finding that the blow back form piercing to be quite a problem. I have tried changing the height, using anti splatter with little improvement. Changing the cut height to 0.08" helped from crashing into the top slag, but I have burnt through a couple of shields in the process. I have similar issues with Aluminum since it doest oxidize either. Is unshielded consumables the best for non-ferrous? Any other Tips?
    Will
    Mar 2009
    924
    Quote Originally Posted by will_eng View Post
    Will
    Try and get further back for the pierce, bad pierces are worse on wear than being too far away, especially when working with hi $$ SS
    I did some 1/2" AR500 today (using 60amp stuff) at .24 pierce height, 1.5sec delay, and down to .11 for cut height, froze Z, and went 55% speed of 24ipm. Leads were dead center and no lead out. Holes were .53" on top and .49" on bottom, a little nip with a die grinder and they were .52" (spec).
    WSS
    www.metaltechus.com
  1. PM1250 Power Dial
    By Stout in forum Hypertherm Plasma
    Last Post: 10-17-2012, 01:26 AM
  2. PIERCE PLASMA help?
    By tibet in forum Waterjet General Topics
    Last Post: 10-07-2010, 11:49 PM
  3. HYPERTHERM PM1250 cut chart input
    By WSS in forum Waterjet General Topics
    Last Post: 10-05-2009, 05:34 AM
  4. pierce hole?
    By slammedxonair in forum DynaTorch
    Last Post: 05-11-2009, 03:12 AM
  5. Pierce Delay even when set to 0?
    By Wolfesmetalfab in forum Mach Plasma / Laser
    Last Post: 02-03-2009, 05:00 AM
