So I'm cutting TONS (as in thousands) of small parts, say 1" x 2" out of 1/8" 6061-T6 aluminum plate. I'm using 3-flute high-helix cutters and full coolant. Everything goes great but the way I mount the parts is really time consuming and I want to learn how to speed up production.
Here is my current process:
1) Turn on and home the machine (once per day)
2) Set the work offset to the edge of my fixture jig - this is low accuracy but more than good enough for my process (once per day)
3) Take a 12 x 24 piece of aluminum, a matching piece of 1/4" plywood and a spoil board and clamp them to the fixture jig using c-clamps and/or welding clamps. This is only temporary until the next three steps are done.
4) Touch off the surface of the metal using a Tomach-style dial indicator.
5) Insert a 1/4" drill bit.
6) Run g-code that drills 1/4" holes through both the aluminum and 1/4" plywood.
7) Remove the clamps and pull the spoil board off.
8) Bolt down the aluminum and plywood (which is the new spoil board) to my fixture plate using 1/4-20 bolts.
9) Touch off the surface of the metal using the indicator again.
10) Run actual part program and change tooling as needed.
All of the tooling is using the Tormach system (I love it!) and pre-measured in Mach 3 so tool changes are quick. Additionally, I have all the tool operations quite optimized for feeds and speeds to keep times down. Finally, I have all the tools sorted for efficiency in g-code. Long running operations are at the end so I can leave the machine unattended once the initial holes and the like are drilled. Effectively, a 3 hour operation requires my involvement for only the first 20-30 minutes before it gets to the last tool which runs quite a while.
What I'm looking for is a way to speed this up. Drilling the holes in the beginning takes an absurd amount of time as I need to manually clamp and unclamp every part and swap out all of that. Additionally, all of the bolting and unbolting is a pain too. I'd make a lot more sense to avoid this step entirely but I just don't know how to do it. It seems to me that a vacuum system would be ideal but I'd need to make it myself.
I'm good with making the vacuum pump/tank side of things - I've got a bit of experience with pneumatics so I feel confident there but the vacuum jig stuff is the tricky bit.
So this long rambling post has two specific questions:
1) Do you have any suggestions on improving my process?
2) Do you have any pictures of examples of a custom DIY vacuum jig so I can see the basics of how they work? I've never seen one for metal in person and I imagine mine needs to be quite custom to pull it off.
Thanks in advance for the help!
-Mike
