Hi fellow Fadal fans!
I have a 4020 HT from 93 which I bought used a year ago. The spindle has always been kind of noisy, but never when turning by hand. I asked Fadal about it and as this is a grease packed 10K spindle they said there is not much to do about it as far as oil, maintenance and so fourth. Now I am restocking lube and flipped through the machine maintenance manual and what do I see; A note about using Mobil Heavy Medium oil for the Hi/Low something if the high torque option is installed. There are no pictures and as far as I can tell there is no hydraulic oil tank on the machine. Is "high/low" something about gear change? On the manifold block under the electric cabinet there is one line for High/low, but I think it is hooked to either air or the normal way lube pump.
could it be that it SHOULD have a hydraulic unit to help force lube into the spindle at high rpm's? If that is the case and I nver got the hydraulic unit, no wonder it is noisy! The Fadal manuals are the best, but this topic is not really covered unless it is in another manual I dont have.
Cheers,
Andy
