588,477 active members*
5,653 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Torq-Cut 22 -- "New to me" issues
    Dec 2015
    I recently obtained a TorqCut22 and am having problems getting anything going. When I try to home the axis, i get a "probe fault (unexpected touch)" error message. I'm assuming this is referring to the renishaw type probe that can be installed, but that has never been added to this machine. We have a standard bit in the spindle. I can turn the probe "off" and go to the general menu options. But then when I try to manually start the spindle, I get an error message saying probe hasn't been homed. Any thoughts on why I am getting this "Probe fault" error message?
    Nov 2016
    14
    Re: Bridgeport Torq-Cut 22 -- "New to me" issues
    I'm just shooting in the dark here. But it sounds to me like some of the probe wires might be shorted out causing the machine to think the probe is installed in the spindle. You might try and inspect the wires in and around the probe plug on the front of the spindle as well as the wires going back to the cabinet.
    Paul
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. Torq- Cut 22 - "PM Spindle not up to speed in time"
    By newpaltzwonder in forum Bridgeport / Hardinge Mills
    Last Post: 07-10-2013, 03:47 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
