587,999 active members*
1,933 visitors online*
    Jun 2007
    22
    Cam to gcode problem
    Hi everyone,
    First off, I hope that this is the right forum for this question, and hopefully it's a common problem.
    So, I made my first drawing in Qcad, then generated a tool path/gcode in sheetcam demo and I ended up with a huge circle for a tool path, as well as what I actually drew out in cad. I tried lazy cam thinking it was a sheetcam problem and it rendered the same results. So, I'm guessing it's a cad problem somewhere?
    Any suggestions would be much appreciated.
    Oct 2005
    1237
    Most likely a G2/G3 mix up. I've seen this problem myself. Easiest was is to single step throiugh the program until it hits your crop circle, then fix the code.
    Jun 2007
    22
    Ok, that worked when I edited the g-code. It did not remove the "crop circle" in the tool path display however.
    What should I look for to correct the problem when the code is generated?
    ~B
    Mar 2005
    10
    crop circle
    Sonicmook56,
    Maybe a standard/metric issue?
    Just a guess...
    Nick.
  1. Help with gcode
    By sunlight in forum Mach Mill
    Last Post: 11-13-2007, 01:49 AM
  2. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  3. Help with gcode
    By chas in forum G-Code Programing
    Last Post: 02-19-2005, 02:05 PM
  4. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  5. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
