588,506 active members*
5,542 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Bridgeport Retrofit Using Brushless AC Servo Motors?
Results 1 to 7 of 7
    Nov 2004
    96
    I have a few Brushless AC Servo Motors and drivers that I was thinking of using to convert my Bridgeport knee mill to CNC. Can anyone tell me if they are good enough for this application?
    Y-2023 series
    4500 RPM
    Power 0.91KW
    Continuous Stall Torque 2.5 N-m (22.5 lb-in.)
    Peak Stall Torque 7.1 N-m (63 lb-in.)
    2000 Count Optical Encoder
    3.5" bolt circle mounting
    I have only have one of these....
    F-4030 series
    4000 RPM
    Power 1.4KW
    Continuous Stall Torque 3.5 N-m (31 lb-in.)
    Peak Stall Torque 11.3 N-m (100 lb-in.)
    Nema 56C mounting
    Here is a (large) PDF for both Motors
    http://www.ab.com/manuals/gmc/GMC-SG...4_1_Motors.pdf
    Thanks.
    --Eric
    24221
    I have a couple of Excello knee mills with brushed motors that size, you could put the larger size on the Y as this motor usually carries the X table also. Mine are toothed belt drive with 2:1 reduction.
    Al
    Albert E.
    Nov 2004
    96
    So what else do I really need to convert this to CNC (control wise)? I have the servo motors and the AC drives for them which will accept step and direction signals. Do I just need something like Mach2 and hook up the parallel port of the PC to AC drives?
    Or do I need some kind of multi axis controller PCB?
    24221
    Depends what you want to spend and how sophisticated a system you want. Don't forget you will also want ball screws on all three axis and will need to add a Z axis control to the quill.
    Al
    Albert E.
    Nov 2004
    96
    I don't need something super expensive or sophisticated since this is not for produciton work or making money. I just need something so I can cut metal for my projects, motorcycles, jet skis, 4x4s, etc. I want to be able to cut arcs, large circles, 3D shapes, etc. I don't know if that means I need something more powerful than Mach2 and step and direction from a parallel port or if I need a multi axis motion card???? As far as the servo motors go, I think a 5TPI ballscrew with a 2:1 pulley reduction will give more speed than I could need ~ 400 IPM = 4000rpm / 5 TPI / 2:1 reduction.
    I just want to mess around with an x-y CNC first and then I can worry about making the quil the z-axis and maybe my rotary table 4th axis.
    I mostly machine aluminum and mild steel.
    Thanks for any input.
    Jun 2003
    866
    I am renovating a Bridgeport using Electrocraft motors, one is a 4030. This is a high end setup particularly well suited for CNC. I'm using Electrocraft drives which can take step and direction. EMC, Mach2 or Turbocnc will all work with this setup, and you avoid spending $700 on an interface card. Suggest you go with a breakout board for the parallel port.
    You might want to check out the project logs for mills, there is mine and one that actually a conversion, which sounds like what you are doing. You can find it here: http://www.cnczone.com/forums/forumdisplay.php?f=221
    Nov 2004
    96
    Yes, these are very high end (expensive) motors and drives. I have three Ultra 100 series 2KW drives for each of these and they will take step/dir as inputs for getting your system up an running fast. They also accept +/-10V analog (16bit) inputs and have encoder outputs so you can hook them up to a motion control card later on down the road.
    Here is the PDF for the F-Series motors:
    http://www.ab.com/motion/ec/f_series.pdf
    Here is the PDF for the Ultra 100 series drive:
    http://www.ab.com/motion/drives/1398-1.0.pdf
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. DC motors worthy of being a servo?
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 07-22-2006, 07:25 AM
  3. 3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design)
    By StressedMech in forum CNC Machine Related Electronics
    Last Post: 05-15-2005, 05:26 PM
  4. 3 servo motors - What are the actual specs?
    By Bloy2004 in forum Servo Motors / Drives
    Last Post: 06-10-2004, 07:36 PM
  5. New Contest WIN SERVO MOTORS!!!
    By cncadmin in forum Community Club House
    Last Post: 07-18-2003, 08:16 AM
