588,244 active members*
4,353 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G540 and 2 powersupplys possible ?
Results 1 to 6 of 6
    Nov 2008
    66
    Hi there,
    Just bought the PSU for the machine I intend to put together.
    50V 10amps PSU.
    From what I understood -to drive 4 axes at the max capacity of 3.5Amps
    you would need a minimum of 10 Amps from the PSU.
    If the PSU has only 10 A you would have nothing to spare and I understand the PSU is best to have amps to spare.
    Question is - can I rig 2 PSU's with the G540, and how should they be wired ?
    Regards,
    Florin
    Happy Holydays !!! All the best.
    Jul 2007
    1602
    A 50V 10A power supply should be adequate. The rule of thumb is 2/3 the total amp rating of the motors so 3.5 * 4 * .67 - ~9.4
    Mar 2008
    3655
    You usually don't use 4 motors of equal torque. You probably need either a heavier motor on the Z axis or 3 lighter motors for the other axes. What machine are you using these motors on?
    CR.
    Nov 2008
    66
    Gantry type 1300x900x200
    all motors are the same, nema 23, 425 oz, they were too cheap to bother with different torque ones.
    Mar 2008
    3655
    OK, it's a router not a mill. X has 2 motors driving it? Should be fine then.
    CR.
    Nov 2008
    66
    Thanks for the answers,
    today the motors just arrived and Surprise - they shipped different ones, intentionally or unintentionally.
    Ordered from Zapp Automation UK, it seems I'm not the only one that got different motors.
  1. Gecko G540 on a minitech minimill 2
    By Fixittt in forum Benchtop Machines
    Last Post: 06-07-2009, 05:31 PM
  2. New stepper for Gecko G540
    By automationtechinc in forum News Announcements
    Last Post: 01-29-2009, 05:18 PM
  3. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  4. Gecko G540 and Motor mH rating
    By ronateah in forum Gecko Drives
    Last Post: 11-18-2008, 05:05 PM
  5. My Powersupply
    By barkster in forum CNC Machine Related Electronics
    Last Post: 04-12-2004, 04:27 PM
