Hi George,
Picked this reply of yours out of a past post. "Put the machine in a slow feed rate. Does it move smooth? If not the motors may need brushes or cleaning."
Table on my BOSS 8 does not move as smoothly as I feel it should when I machine at feed rates, works OK in rapid moves. Mill is used 75% of time for drilling holes. Checked the brushes on the X-axis, small brushes seem quite long, large brushes seem short. Can you give me a ballpark length on large brushes?
Right now I do not wish to remove and clean motors as I have several weeks of drilling to run on this machine before I can shut down.
Thanks, for you advice, Jim
