588,049 active members*
4,067 visitors online*
    Sep 2007
    122
    Mitsubishi 4th axis drive
    All,
    On our Mazak 510C II I am getting an F4 18 alarm on the Mitsubishi 4th axis drive – MDS-DH-V1-20. The screen is displaying a 31 servo malfunction. The cable rang out OK. Can anyone point me in the right direction?
    :drowning:
    Sep 2007
    122
    Troubleshooting the Alarm 18 Mitsubishi guide.
    Alarm No.
    18
    Motor side detector: Initial communication error
    Initial communication with the motor side detector failed.
    Investigation details Investigation results Remedies SV SP
    1 Check the servo parameter The value is not set correctly. Correctly set SV025.
    (SV025.ent) setting value.
    OSE104: 0, OSA104: 1
    Are all others set to 2?
    (Excluding slave axis for
    synchronous control)
    The value is set correctly. Check the investigation item No. 2.
    The connector is disconnected (or
    loose).
    2 Jiggle the detector connectors (drive Correctly install.
    unit side and detector side) and
    check if they are disconnected. The connector is not disconnected. Check the investigation item No. 3.
    3 Turn the power OFF, and check the The connection is faulty. Replace the detector cable.
    detector cable connection with a
    tester.
    The connection is normal. Check the investigation item No. 4. �� ��
    4 Replace with another unit, and check The alarm is on the drive unit side. Replace the drive unit.
    whether the fault is on the unit side or
    detector side.
    The alarm is on the detector side. Check the investigation item No. 5. �� ��
    5 Check if there is any abnormality in
    the detector's ambient environment.
    (Ex. Ambient temperature, noise,
    grounding)
    Take remedies according to the causes of the abnormality in the ambient
    environment. �� ��
  1. mitsubishi MR-J2-C-S100 drive help
    By ZAGNUT in forum Servo Motors / Drives
    Last Post: 10-23-2011, 01:28 AM
  2. Mitsubishi servo drive
    By hotrob1 in forum CNC Machine Related Electronics
    Last Post: 08-10-2009, 02:00 PM
  3. Mitsubishi VX-20 Floppy Drive Help
    By ltkettch17 in forum EDM Discussion General Topics
    Last Post: 04-28-2009, 07:42 PM
