![Quote](images/misc/quote_icon.png)
Originally Posted by
HimyKabibble
RPM should be calculated based on the tool material, tool diameter, and the work material:
RPM = SFPM * 12 / ( PI * ToolDiameter )
This can be simplified to:
RPM = SFPM * 4 / ToolDiameter
Typical SFPM Values for HSS Tools:
Cast Iron 30-50
Mild Steel 80-100
Aluminum 400
For Carbide tools, triple the HSS values
So, for a 1/2" HSS endmill in aluminum RPM = 400 * 4 / 0.5 = 3200 RPM
Feedrate = RPM * #Teeth * Chipload
Chipload can be approximated by 0.008 * ToolDiameter, until you get into small, fragile tools (under 1/8"), where the chipload needs to be reduced further.
So, for a 1/2" 2-flute HSS endmill, Chipload = 0.008 * 0.5 = 0.004"
Feedrate = 3200 * 2 * 0.004 = 25.6 IPM
If you work through the calculations, you'll see that until you get into very small, fragile tools, a large diameter tool and a small diameter tool will use the same feedrate, with only the RPM changing. So, if a 1/2" endmill uses 3200 RPM at 25.6 IPM, a 1/4" endmill will use 6400 RPM at 25.6 IPM. If you can't reach that RPM then use the highest RPM you can, and reduce feedrate proportionally. So, if you can only go 4000 RPM, then the feedrate becomes 25.6 * 4000 / 6400 = 16 IPM.
As a rule of thumb, when slotting, if your DOC exceeds 1/2 the tool diameter, you need to start reducing feedrate. As a rule of thumb, reduce feedrate by half at DOC = one diameter. So, for the above endmill:
DOC = 0.25" ==> Feedrate = 25.6 IPM
DOC = 0.50" ==> Feedrate = 12.8 IPM
When making very light cuts (< 1/4 tool diameter), feedrate needs to be increased, to compensate for chip thinning. For the above endmill, if the width of cut is 0.01", you should at least double the feedrate.
Follow the above, and you'll get reasonable starting RPM and feedrate. Getting optimal values requires experimentation, as the best values are different for different machines, and different situations, and can only be learned through experience.
Contrary to common belief, and many peoples intuition, increasing RPM, or reducing feedrate is NOT "easier" on the tool or the machine. Both will reduce chipload, and low chipload leads to the tool heating up. The best way to keep the tool cool is to keep the chipload as high as possible, and the heat will be carried away by the chips, leaving the tool cool. The most common result of a too-low feedrate or too-high RPM is chips welding to the tool. The natural reaction to this is to reduce feedrate, which is exactly the wrong thing to do. When RPM and feedrate are correct, the tool will only get hot on very aggressive cuts - the kind these benchtop machines are not really capable of.
Also, on these benchtop machine with limited RPM, you'll save a lot of money by using HSS tooling, rather than carbide. HSS is more rugged - carbide chips VERY easily. The only time carbide might be appropriate is on small diameter tools (under 1/4"), where the extra stiffness can be helpful. But, on average, GOOD HSS tools will cost less than cheap carbide tools, they'll last longer, and will cut every bit as well. On a stiffer machine, with higher RPMs, carbide can be very beneficial.
My normal roughing cut in 6061 is a 1/2" HSS 2-flute endmill, 3300 RPM, 30 IPM, 0.20" DOC, 0.500" WOC. For finishing, I use 5000 RPM, 50 IPM, any depth, 0.010" WOC. If you can't go that fast or deep, reduce RPM, scale the feedrates by your chosen RPMs, and you should be OK.
Regards,
Ray L.
