588,100 active members*
5,438 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > single axis driver and a b.o.b.,or multi-axis driver board
    Apr 2007
    323
    i was just wondering about the drivers,alot here seem to know alot about stepper driver boards,so my question ,..are 3 single axis driver boards hooked to a break out board (b.o.b.) ,any better than simply getting a multi axis driver .here are a few reasons i can think of
    1.)multi-axis drivers can be alot cheaper to get into(around $150.00for a 3 axis),but if you blow one axis up on a multi axis board,you would have to possably buy a whole new board just to get the one axis fixed,or send the whole board off for repairs,also less components to wire up,and mount
    2.)single axis boards are usualy more expensive up front(around $100.00 each axis),and would need a B.O.B. to hook them all together,but if you blow a b.o.b. you can replace it only,or if you blow one axis,again you can just replace the one axis
    so does that pretty much cover it? or are there some things i have overlooked,which would make one better than the other?
    i was looking at a multi axis kit,and had pretty much made up my mind to get it ,then saw an add here for a single-axis kit with a b.o.b. and every thing, that was needed to get the motors turning ,both were in about the same neighborhood in price so now im back to wondering what might make one kit better than one.you know pro's and con's of each type driver that i havent covered (i dont wanna start any fights ,as all these kits seem like they would be excellent either way, i was just curious)
    "witty comment"
    The single axis boards (typically Geckos) usually offer much better performance to go with their higher price tags. Usually the multi axis boards won't work well with larger motors. But if they'll work well with the motors you'll using, why spend more money? I know Xylotex, for example, will repair damaged boards for a reasonably fee.
    Jun 2003
    3312
    Most of the multiaxis boards I have seen need no BOB. Maybe this will help:http://www.pminmo.com/wiki/index.php...ystem_Overview
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Apr 2007
    323
    hmm..seems like the multi-axis type boards hooked to a b.o.b. might offer better protection? i dont even know what i dont know if i had the money id buy them all so would know..lol the price tag on (some) of these kits are about the same i guess im just weighing the ups and downs of each type when ya can only buy one ya want it to be the best...so many great boards so little money,xylotex, gecko, keling,stepperworld,hobby cnc, almost endless possabilities
    "witty comment"
  1. Good 3-Axis driver board ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 04-11-2007, 04:59 PM
  2. fet 3 15 amp 3 axis driver board (stepperworld)
    By mike10 in forum Stepper Motors / Drives
    Last Post: 04-30-2005, 04:30 AM
  3. 3 axis unipolar motor driver board
    By serkanozfe in forum Stepper Motors / Drives
    Last Post: 02-15-2005, 08:28 AM
  4. Troubleshooting the OS discrete single axis board
    By Konstantin in forum Open Source Controller Boards
    Last Post: 08-24-2004, 10:31 PM
  5. 3-Axis Bi-Polar Driver Board
    By anoah in forum DIY CNC Router Table Machines
    Last Post: 11-04-2003, 06:23 PM
