588,231 active members*
4,339 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Feb 2009
    52
    SHM0609 [Official thread]
    I'm waiting my "little baby" coming home so I think may be a good idea start an Official thread on this machine.
    Some guys on this forum bought it and could help newbie like me or others who want to buy.
    If not useful delete the post
    Official SHM0609 english home page:
    http://www.webshcnc.com/english/6096m.asp
    Official Excitech picture:
    charnwooduk router unboxing post (pictures attached):
    http://www.cnczone.com/forums/showpo...postcount=2279
    First question:
    • what type of maintenance to do when router arrive.
    Attached Thumbnails Attached Thumbnails teamfq 001.jpg   teamfq 002.jpg   teamfq 003.jpg   teamfq 005.jpg
    Feb 2009
    23
    Dear friend ,
    I have bought from China 3 weeks ago an XYZ 6090 and i am in big trouble still.By the look of the pictures of your baby it MAKE a big difference compare to mine.Can you please advise if it came with NC studio program?Did you have any problem with it?
    Looking forward for your reply.
    Regards
    George
    PS:regarding your question of maintenance of the CNC,the most and above all rules from all is clean rails,and sharp tools.
    Feb 2009
    52
    Hi.
    First i don't know what's the Ncstudio, but if I correctly understand:
    The SHM0609 router is provided by the DSP controller that accept the Gcode.
    I found on the forum some posts concerning the NCstudio, hope it help:
    http://www.cnczone.com/forums/showthread.php?t=33069
    http://cnczone.com/forums/showpost.p...00&postcount=1
    the search query:
    http://cnczone.com/forums/search.php?searchid=3423784
    Could you post the home page factory of your machine?
    Thanks for suggestions.
    Feb 2009
    23
    Dear friend
    thanks for the reply,and the company who sell the router is XYZ-TECH_CNC_Equipment_Co_Ltd.
    You see i have bought from the States a new card so i can work with Mach3 instead of the NCstudio wich the router came with.After some reading and searching i came to a STOP with the instalation because the router it has a Hight Frequency inverter to control speed on the motor( DZB brand 200model).
    The reason i have ask you for more information is to advise if you can and obviously if possible for you,to send me a photo of your installation regarding the four wires coming out of the bottom of the inverter .In the standard small break out board(BOB)which came with it goes on a fuse with the following order G(red),1,2,3.
    What program yours came with?
    Is it able to work with Mach or?
    Regards
    George
    Feb 2009
    52
    George, my router is on the way (I'm waiting it within 3 weeks) so unfortunately I can't help you.
    You can try to send a PM to charnwooduk, a forum member, he got the router 3 weeks ago and may help you.
    Take care
    Ciao
    Aug 2008
    12
    Quote Originally Posted by 6bx View Post
    Dear friend
    I suspect that this is a different company to Excitech.
    I found this picture of the "XYZ-tech" 0609 and it looks like a different machine to the one excitech produce - http://www.ttnet.net/show_html.jsp/c...no/000/type1/A
    I am using the DSP to control the machine so cannot advise on how to set-up with mach 3
    Feb 2009
    52
    Yeah, it's not the same router.
    Also specifications are different.
    Charnwooduk, tell me your impressions after 3 weeks of SHM0609 use.
    What type of maintenace you did when you got the router at home?
    Ciao
    Aug 2008
    12
    Quote Originally Posted by woodworker73 View Post
    For maintainance, i simply removed the dust covers for the rails, wiped everything clean and applied lots of grease to the lead&ball screws and wiped oil over the rails.
    Also the machine bed was not quite flat, but as it is a hard plastic "foam", it is easy to mill flat (you can see the pattern left in my pictures.. bed is now perfectly flat.
    I also adjusted the position of the spindle as it was mounted too low. The new position gives the full 120mm of travel (this is a two minute job to complete)
    I am using the VFD control panel to operate the spindle as it did not seem 100% reliable from the DSP, although I have not spent time to investigate the issue (set function F00 to 4 and F01 to 0 on the VFD to enable this)
    Made a vacuum hold down table for cutting some small rohacell parts (see pictures).
    90% of my machine time is cutting 3D, as I am not worried about saving time, my 2D routing is not at very agressive depths.
    Attached Thumbnails Attached Thumbnails teamfq 012s.JPG   teamfq 013s.JPG   teamfq 014s.JPG
    Feb 2009
    52
    Thanks.
    Did you used a gcode to flat the bed or manually via the USB controller?
    Feb 2009
    52
    Router received.
    As first impression it's a good costruction.
    Here some pictures:
    The box:
    The tool box:
    Front Panel with the delta and, on the right, the cord for the zero tool:
    The Hiwin rail guide:
    The ball screw:
    The plaque:
    As wrote the costruction is overall good.
    The only thing is that you can't use a transpallet to lift up the router, there are no solid beams at the bottom.
    I already emailed this to Taney and he prompt reply me that this will be improved.
    I will post others pictures next days.
    Ciao
    Feb 2009
    52
    The zero tool:
    The X axis:
    The spindle:
    The Z axis:
    The electronic:
    Back side:
    Nov 2007
    2466
    i have seen a few of these machines and your photos are great and show what one should expect!! excellent post
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Feb 2009
    52
    Thanks Jim!
    Yours compliments are very welcome.
    Hope to help some one and help Exitech to improove this router.
    Some little things to do (like, not little, remove it from the wood base) and start working.
    Cleaned all the rails and the balls screw from the rust protective and grease them.
    Next step is to understand the DSP.
    Feb 2009
    52
    Z-zero tool using:
    This is what Taney reply me about the Z-zero tool:
    First count the thickness of the brass block, input the thickness value of the tool sensor into the DSP handle: MENU--MACHINE SETUP--C.A.D Thickness.
    Then press MENU+ON/OFF togehter and relase the two buttons at the same time, the spindle will go down, when the tool tip touch the sensor the spindle will go up, and the system will remember the Z-0 point
    I will test it today and let you know.
    Feb 2009
    52
    Firts test
    This is a video of first test I did, a file included into the DSP:
    [ame="http://www.youtube.com/watch?v=0GMJ52gN8E4"]YouTube - Test[/ame]
    machine is working high at 5.49 m/min, homing X and Y at 6 m/min.
    Feb 2009
    52
    Machining the first 3d file I did:
    [ame="http://www.youtube.com/watch?v=3ozamzqC9VY"]YouTube - Primo lavoro[/ame]
    mm 110 x 110
    Tools used:
    1- end mill mm 3
    2- ball nose mm 1.5
    3- end mill mm 3
    Cheers
    Feb 2009
    52
    To pump grease into the Hiwin block nipple you have to use this tool with a "zerch" cap:
    Dec 2006
    878
    Sensational thread!!
    Congratulations woodworker.
    The photos are excellent
    The youtube videos are great.
    Commentary also excellent.
    You are operating your machine like a seasoned professional already.
    Great work.
    Look forward to seeing more!
    Rocket.
    Feb 2009
    52
    Thanks rocket, you are very welcome
    May 2009
    5
    As anybody managed it yet to control the spindle speed via the DSP?
    Regards, ray
Page 1 of 2 12
  1. SHM0609 lubrication
    By carveit in forum Excitech routers
    Last Post: 02-27-2010, 12:33 PM
  2. Replies: 7
    Last Post: 09-02-2009, 11:32 AM
  3. Cap and Trade to be Official Policy
    By dynosor in forum Environmental / Alternate Energy
    Last Post: 03-26-2009, 05:29 AM
  4. SHM0609 to buy and users experience
    By yksur in forum Excitech routers
    Last Post: 02-10-2009, 02:56 PM
  5. TEKdrive Servo Drive Official Release Today!!
    By Kookaburra in forum News Announcements
    Last Post: 05-14-2006, 11:32 PM
