587,224 active members*
3,135 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Help needed upgrading CNC components while maintaining use of Mach3 Mill
    Jun 2015
    9
    I have an old CAMaster MC-2840 machine from 2009. It has worked great, but when I had some issue(s) a couple weeks ago, the team at CAMaster could not help because nobody knew the components of my machine. Thus, I'd like to upgrade it all with the latest and greatest to eliminate any probable downtime.
    Current MC-2840 specs:
    • Stepper motors are 23H276-28-4B (x- and y-axis) and 23H300H-05B (z-axis)
    • Running Mach3 on a Windows XP Home Edition, Service Pack 3 PC. Intel Pentium 4, 2.66GHz and 1 Gb RAM.
    I like Mach3, so I hope we can stick with it even after upgrading all the components.
    How can I upgrade this machine? Any and all advice is recommended.
    Regards,
    Bryan
    Re: Help needed upgrading CNC components while maintaining use of Mach3 Mill
    How big is the machine?
    Those motors are pretty small.
    The simplest solution would be to get a Gecko G540 or Leadshine MX4660.
    Jun 2015
    9
    28" x 40". Only currently use it to cut .125" 6061-T6 aluminum.
  1. upgrading Mach3
    By JustinHoMi in forum Tormach Personal CNC Mill
    Last Post: 06-23-2015, 10:07 PM
  2. Should Master Maintaining Tips of Small Pellet Mill
    By logia in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-26-2015, 10:13 AM
  3. Help needed with Aluminium components
    By JPSchulze in forum Australia, New Zealand Club House
    Last Post: 03-05-2014, 01:42 PM
  4. Upgrading to CNC Mill
    By sturgeo in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2010, 09:28 PM
  5. Upgrading Mach3 CNC w/MP1000-THC
    By ptig185 in forum Mach Plasma / Laser
    Last Post: 07-26-2008, 11:39 AM
