588,134 active members*
5,414 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > M code operated clamp for rotary operation?
    Mar 2008
    638
    We're making a cylindrical long thin part with a slot thru both sides. Held in a collet in the rotary is the main fixture and it's supported by a tailstock. The part slides onto the main fixture and it's secured with a bushing and nut.
    It's being made on a Haas VM-2 with a Rotary. Right now I'm putting M00s in to let me add/move a clamping fixture in two spots of the program.
    I've seen videos of a machine that has a clamp built into it. Has anyone done this on a Haas? Pretty sure we have spare M codes.
    Chris
    Nov 2006
    490
    Re: M code operated clamp for rotary operation?
    You can definitely add that hardware into the fixture, but it'd take some building and wiring on your end. Hooking up a solenoid is probably the easiest part, it's everything else that would take time!
    Mar 2008
    638
    I've priced some pneumatic vises that would fit and they are expensive. Thanks for answering.
    Nov 2006
    490
    Yeah they can be fairly expensive especially considering pneumatic vises have less clamping force compared to a traditional mill vise. They can only be used for certain applications due to the less force.
    I have one that I use with a foot pedal, but we use dovetail-shaped jaws with it that prevent the part from being pulled upwards, which then obviously adds the preliminary dovetail cutting operation into the mix.
    For your workpiece it might be fine, since using smaller tools generally don't produce enough force to cause problems like that.
    If you need higher clamping force then hydraulic vises are the way to go, but they are much more expensive and harder to maintain...
    Mar 2008
    638
    For our application the pneumatic ones would be fine. It won't be the main fixture as you've surmised but merely there to stop the part from flexing after the slotting operation. I suspect I'm going down a blind alley. The cost so far seems out of reach for the quantity we make.
    Thanks Ydna
  1. m code or operation manual
    By rathi_vk in forum CNC Machining Centers
    Last Post: 10-10-2014, 08:53 PM
  2. M-code for Chuck Clamp/Unclamp
    By stuby in forum G-Code Programing
    Last Post: 01-21-2011, 04:30 PM
  3. Four axis rotary operation
    By shubSly in forum EdgeCam
    Last Post: 06-05-2008, 02:48 PM
  4. G-Code Spindle Operation
    By SyilAmerica in forum Syil Products
    Last Post: 03-07-2007, 09:09 PM
  5. Generate G-Code for end-milling operation
    By vijaychd in forum G-Code Programing
    Last Post: 06-02-2005, 09:46 AM
