588,410 active members*
5,351 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF1 Tool Changer Problem
    Sep 2013
    13
    The problem I am having is that the tool changer will come in and operate properly w/o a tool in the spindle. When a tool is in it and tries to do a tool change it will alarm out. Limit switches ok, the problem I see is that with the tool in, the arm that rotates on the motor will not go up. Is it time to replace the clutch? Or is there a way to clean it?
    Mar 2010
    1852
    Why are you posting the same problem again? Have you fully done what was mentioned in the other thread, which is just a few threads below?
    You must give exact details and then follow instructions. There is only one arm you can see without removing covers and that is the arm that moves the shuttle in and out, not the one that rotates the turret. Again, give exact details step by step of what happens. There is no magic button to push that will fix your problem. A video would be great too.
    Sep 2013
    13
    Yes, the arm that moves the shuttle in and out. The other problem was for my dads machine, Limit switch was the problem. I did not say the turret.
    Mar 2010
    1852
    The arm that moves the shuttle in and out will not change in any way just because there is a tool in the spindle. Does not make a bit of difference, they are separate mechanisms.
    There is a non-adjustable clutch on that arm where it attaches to the motor, but usually it is just the set screw that loosens up. Had to get to, but you can.
    Mike
  1. Old Haas Tool changer problem
    By rick352fe in forum Haas Mills
    Last Post: 10-02-2013, 08:54 PM
  2. HAAS VF-3 1997 Tool changer problem
    By Hames in forum Machinery Manuals / Brochures
    Last Post: 01-09-2013, 05:07 AM
  3. Haas tool changer
    By penjas14 in forum Haas Mills
    Last Post: 01-23-2009, 12:46 AM
  4. Haas vf0 tool changer problem alarm 114
    By nevron in forum Haas Mills
    Last Post: 05-07-2008, 08:36 PM
  5. tool changer problem on haas mini mill
    By Greg 24 in forum Haas Mills
    Last Post: 03-05-2006, 09:20 PM
