Hello,
I'm studying the excellent book by Smid on gcoding.
on a lathe When doing an independent (of movement) compensation how does the control know in what direction to move
to compensate for the tool nose radius comp amount stored in the R column in the machine tool offset table - activated by the last two digits of the T command,
Since no G41,G42 command is given?
for instance - N1 G00 T0202.
please see below snippet from chapter describing lathe offsets:
IIndependent Tool Offsetpage 304 Chapter 34 cnc programming handbook peter smid third edition.For an independent offset entry in the program, tool offset
is applied together with tool indexing:
N34 G00 T0202
This command is usually programmed as the first block
for each tool (in a clear position).
At this point, the tool is still at its indexing position.When tool
offset is activated, it will cause a physical motion by the
amount stored in the offset register.
Thanks in advance for any replies!!
