588,487 active members*
5,307 visitors online*
Results 1 to 17 of 17
    Feb 2015
    166
    breakout board question
    right now i have a c35s bob
    uunless im doing it wrong ..im out of inputs
    estop 10
    probe 11
    x y and z limits 12..13..15
    i want to hook up an index signal for tapping... and also want to add a 5th axis down the road...
    can you guys recommend a BOB that will allow me to do this ..
    or can i add an expansion board ....
    your input is appreciated as always
    rick
    Nov 2009
    4415
    Re: breakout board question
    You could hook all of your limit switches to 1 pin. Mach knows which axis is moving. This would save you pins and the purchase of any new equipment. 5th axis? What software?
    A lazy man does it twice.
    Feb 2015
    166
    hey boss
    i tried using pin 11 for all limits... it wont work... im using c35s with the rj45 connectors... im thinking it automatically grabs a pin because of the way the rj45s are setup......the limit switch loom i bought is rj45... im not sure i can assign one pin... unless im doing it wrong..i tried assigning all linits to one pin ..11 then 12 then 13 ... but only one axis at a time would home ... its like the rj45 setup has already decided what pin its going to use..
    unless theres a way to make mach forget what pin it used to have assigned to a particular limit i think im stuck
    im working on a harmonic drive based trunnion table... planning in using powermill
    Nov 2009
    4415
    Yes if all of the limit switches are connected to a single pin, only one axis will be in motion at a time during the homing sequence. Since I only home during the set up, there is no time advantage.
    Nov 2012
    1280
    Quote Originally Posted by 1hander View Post
    hey boss
    Well, first you have to physically rewire your switch harness so all of them are wired in series and connected to the same physical input. Can't do it in the software alone.
    1943
    Quote Originally Posted by CitizenOfDreams View Post
    In series if using normally closed switches. If using normally open switches you would wire them in parallel
    Nov 2012
    1280
    Quote Originally Posted by 109jb View Post
    Yes, thanks for the clarification. Mechanical limit switches are usually normally closed for safety reasons - if the switch malfunctions, the wire gets broken or the connector gets unplugged, the machine will stop.
    Sep 2006
    509
    You could add a second parallel port card to the PC for additional inputs. Not sure how that works in Mach 3 but easy to do in LInuxCNC. The cards are super cheap (~$10) from various china sources.
    Mike
    Nov 2012
    1280
    Quote Originally Posted by ninefinger View Post
    Mike
    In Mach3 it is trivial as well, every input in the program configuration is defined by the pin number and the port number.
    Mar 2007
    2083
    you might find its easier to wire the switches to the terminal block
Name:	C35 input rj45 & terminal block.jpg
    how are the limit switches wired now ?
    if its like this
    Attachment 336040
    with 3 pairs of series connected normally closed switches
    you can not simply wire the 3 wires to the RJ45 pins 2,3 & 4 in parallel
    the simple solution is to cut off the RJ45 connector and wire all switches in series and connect them to 1 input
    alternatively find or build an AND gate interface to use the limit switches and C35 as supplied
Name:	C35 input terminal.jpg
    original input wiring
Name:	C35 input terminal + 3 limit switches.jpg
    using AND gate to connect 3 axis limit switches to 1 C35 input
    john
    Attached Thumbnails Attached Thumbnails C35 input terminal + 3 limit switches.jpg
    Feb 2015
    166
    rewiring is what i didnt want to do... since i am a beginner the rj45 stuff mades it clean tidy and easy ... for dummy like me LOL...
    i can add another parallel port card but i dont think its as easy on mach as it is on linux for extra inputs..
    and since i want a 5th axis capability.... i think im going to have to get a c32s or c62 and a c24 parallel port card
    i see output expansion cards but i dont see any input expansion types...
    Mar 2007
    2083
    if you had been happy building an adaptor this could of freed up some input pins _
    Attachment 336086
    alternatively by adding a second printerport and C10 bidirectional board
    mach3 can either give you an additional 4 outputs and 13 inputs or 12 outputs and 5 inputs
    since you only want to use ready made boards with the RJ45 connectors
    it looks like the CNC4PC C32 dual port multifunction board and second printer port is the only option
    as they don't seem to make a version of the C10 bi direction board with RJ45 connectors
    John
    Attached Thumbnails Attached Thumbnails C35 input terminal + 3 limit switches common gnd.jpg
    It's probably even easier in Mach3.
    Nov 2009
    4415
    Plug in the 2nd card and assign the address in Mach. Assign the pins. That is it. Though I didnt say it before, those RJ45's suck. I went that route at one point.
    Mar 2007
    2083
    expanding on post 12
    for any one taking a DIY approach to connecting the a ready made switch assembly like the A32R2 to the single RJ45-8 input
    one possible solution avoiding cutting off the RJ45 connector from the switches
    Attachment 336162
    version 2
    Attachment 336186
    I must admit I would connect the limit switches directly to the C32 breakout boards terminal block
    John
    Nov 2012
    1280
    Quote Originally Posted by john-100 View Post
    So would I. If you want to have a quick disconnect, there are industry standard two-part terminal blocks - much more robust and flexible. RJ45 does not really belong there.
    Feb 2015
    166
    i agree the rj45s make it hella confusing for me because theres no way to see which pin the contacts are assigned to..i know that now LOL
  1. Replacing a burned breakout board, pinout question
    By kievari in forum CNC Machine Related Electronics
    Last Post: 12-19-2014, 02:42 AM
  2. breakout board question
    By gurasha in forum Stepper Motors / Drives
    Last Post: 05-09-2013, 05:41 AM
  3. CNC newbie question Servo+driver+breakout board?
    By wolfmetalfab in forum Servo Drives
    Last Post: 05-11-2006, 07:43 AM
  4. breakout board 200khz option question
    By h_2_o in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 10:52 AM
  5. Question PMinMo Breakout Board
    By huckshooter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2005, 03:46 PM
