![Quote](images/misc/quote_icon.png)
Originally Posted by
dcoupar
I highly recommend shielded cables. If you can send and receive to/from this control with the same PC using shorter cables, then the problem has to be something in the cables/switch box. Have you tried the same cable without the switch box? Have you tried putting a simple RS-232 tester on the end of the cable and watching to see if the LED's show data flowing when you send to the machine using the long cable?
Re: the PCMCIA memory card. I personally don't recommend that if you can get the RS-232 working, as I know of at least 2 customers who have damaged the connector when inserting the card, and had to call Fanuc in to repair it. Luckily, in both cases the controls were still under warranty. Don't know what the $ would have been if they weren't.
