588,159 active members*
4,918 visitors online*
    Sep 2008
    16
    GridShift zero y
    I have a machine with Fanuc 18i SIGMA. Have encoders and optical scale on all axes.
    I want to make a Gridshift of zero y-axis, I tried the 1850 parameter and not the result . Only with values more+ -2000 it have changes and shift about 17mm .
    The machine doesn't have zero switches.
    Vide
    Jun 2009
    16
    you can use 1815 APZ
    Nov 2010
    position the axis to its reference position manually, input pwe = 1 then on 1851 set to a 1 then back to zero, this should set the abs encoder, then pwe = 0.
    Sep 2008
    16
    solved
    thanks
