I'm not a mechanical engineer, just a dumb electrical one. I want to build a simple CNC machine (for plasma) that can easily be stored, so I came up with this design. It is designed to be mounted to a solid wall with the gantry sticking out from the wall, but the gantry can fold away so that it only takes up a few inches when folded. That means my Z movement is moving lots of mass, and my Y movement isn't. See attached drawing. The drawing is not complete, does not show motors, chains, belts, counter weights or springs for Z, etc. but does show the general design. Note, the lower left drawing doesn't show all of the Y components, it started getting too complex.
Does this design look like it could work? One advantage is that I can put things at different height under it. So, I can use a table if I want, or I can run the hood of my car under it if I want to.
I'm building this in Shanghai China, so aluminum is a lot cheaper, as are Thompson type linear bearings, so I'm using both. I'm using steel for the stationary part for strength.
Any comments GREATLY appreciated as I don't want to start shelling out money for aluminum if it ain't going to work well.
