can anybody explain how the microstepping feature on keling drives work.
can they be used to come up with the same steps per unit as say a gecko drive? I am trying to mix and match drives under mach3 and the basic numbers don't com out. the best I can come out with is (1 step per rev) in the motor tuning section. the rest of the numbers don't even make sense.
the 1 step er rev will make the keling drive accurate but not compatible in any way. the conclusion. speed is so slow that it cannot be ran in mach3 or compatable with other drives. I thought that. apparently microsteps have different meanings in different drives or have no resolution at all. any light would be appreciated.
thankyou
