588,484 active members*
5,337 visitors online*
Results 1 to 12 of 12
    Nov 2007
    4
    Fanuc 6T-B Geometry offset
    I have an old Yam-CK2 lathe with a Fanuc 6T-B control. Does anyone have any information on activating geometry offsets??
    Apr 2006
    3206
    Quote Originally Posted by bogdanz View Post
    Check back here 8 hrs from the time of this post. I'll have some info that will help.... Off to dinner now!
    May 2004
    4519
    Good old YAM chucker. I ran one for about 3 years. No info to help though. Sorry.
    Apr 2006
    3206
    Ok. Back. Dinner was good.
    What exactly is the issue? Basic tool offset pairs or nose radius comp?
    Apr 2006
    3206
    Glad I ate first!!!
    Apr 2006
    3206
    Well, since yesterday when I said it's a good thing I ate first, I've had another 4 meals.
    I guess it just wasn't that important. Or maybe mom took away his internet privileges.
    Nov 2007
    4
    The problem is that I just bought this machine and it does not have geometry offsets. Without this feature the the tools are defined within the program with a G50. This is stoneage, even my older machine with a 3T control has these offsets. I'm looking to activate this feature.
    Thanx
    Bogdan
    Nov 2012
    70
    You may have to contact old uncle Fanuc. With wallet wide open
    Nov 2007
    4
    From what I found out it is a bit#2 of a parameter#302 but I'm unable to change it. I talk to someone abut it, and he said that I have to upgrade memory from 8k that I have now, to at list 32k. Can any one confirm that?
    Nov 2012
    70
    Sounds logical that an offset register will take up memory capacity
    So probably you will have to pay both for a memory board and for unlocking of the parameter
    Nov 2007
    4
    Just got my self used A87L-0001-0017 for $87 from ebay. Will see if that will help.
    Nov 2012
    70
    Good start. But you still have to unlock and change the parameter. Now you can use the saved money on the used board on Fanuc helping you if no helpful competent angel appears. Good luck !
  1. Replies: 16
    Last Post: 10-12-2012, 12:43 PM
  2. mits 520am control geometry/wear offset even available?
    By rapid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2012, 10:52 PM
  3. Tool Geometry / Offset
    By WaterjetWillie in forum Daewoo/Doosan
    Last Post: 06-12-2010, 05:10 PM
  4. Tool geometry offset Y-axis
    By Dlo in forum Mori Seiki lathes
    Last Post: 05-13-2010, 07:26 AM
  5. Lathe geometry offset
    By cncdigger in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2007, 11:52 PM
