Originally Posted by
neomagik
Please help,
I've just finished building my first cnc machine and I'm testing the motors before I attach them.
Using Mach3 motor tuning, I can't get them to turn above 135 mm per min without stalling.
Other values are:-
steps per = 1800
acceleration = 2mm/sec/sec
step pulse and dir pulse = 0
Kernel Speed is 25000Hz
Motors are NEMA 23 Stepper Motor MY103H702
Controller is 3 Axis TB6560 CNC Stepper Motor Driver Board Controller
Power supply is 24VDC 10A
DIP settings are:
Current setting - 75% (turning this down/up stills stalls motor)
Decay mode - don't really know what this is and can't remember setting
Microstep setting - 1/2
Any help would be greatly received.
Rob
Hi Rob,
Those motors are very high inductance for their current...10mH and 1.4A. I have the same motors and they stall out in free air, no load at 300rpm with my driver, half stepping I can't coax them above 2000stesp/sec. You say 135mm/min, but you don't say what pitch leadscrew... 1800 steps per ?
75% setting on those boards is roughly 1.2 or 1.5A depending on which supplier you got it from (.33 or .22ohm sense resistors). The decay setting will make little difference, but fast decay is the better one, however the diodes they use are not best suited for the job so there is a lot of residual energy in the motor coils even on fast decay and this gooes towards limiting limiting the maximum step rate.
At 24v the corner speed on the motor is about 330rpm and torque drops off really fast above that...
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
