587,610 active members*
3,504 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Post Problem/Post needed
Results 1 to 7 of 7
    Mar 2013
    Angry Post Problem/Post needed
    Hi All,
    I am in need of some help relating to a post I have. It is not currently outputting the correct codes, after posting, and i cannot seem to get it right, no matter what i change. Does anybody have a post for a Fagor 8025/8030 models T, TG,TS?
    As you all know this is a frustrating part of Edgecam, and I would appreciate the help.
    Many Thanks.
    Dan
    Jun 2008
    125
    Are you on a maintenance contract with the UK direct Edgecam guys? If so, they should be your first port of call. Am pretty sure they'll have a Fagor post, or if you don't want to buy one they should be able to advise you.
    Alternatively post up your issue here with some details and someone will help you out. Ideally attach your post, ppf and required nc code.
    Mar 2013
    No, i'm just a run of the mill CNC programmer, looking for some assistance. I am currently speaking to Edgecam, but i was trying to attack all possibilities at all angles. This is my first time on here, and i dont know how 6to attach! i need some help with that too!!
    Jun 2008
    125
    Yeah I was having problems trying to attach files today.
    BTW what version of Edgecam are you running? If it's the same as me I'll let you have my email and you can send me the files direct.
    Mar 2013
    I have just updated to 2013 r1. My e-mail is [email]Thanks
    Jun 2008
    125
    Hi Dan. I sent you a DM, so check your inbox. I couldn't email you direct. Maybe best if you remove your work email from public view.
    Jun 2008
    125
    Hopefully all sorted now.
    Main problem here was Dans post contained ;code like this .....
    %IF #COMMENTNEXT=#TRUE %THEN <[#DELETE=38][#BNUM=34] ([USERDEFINEDSTRING])>:#COMMENTNEXT=#FALSE.
    I would recommend you never use this kind of output. You can see the numbers =38 and =34 in this case. What this refers to is the position in the format table that the block number is going to take. So when this initial snippet of code was written the 34’th place in the format table would have been the block number (ie N). However as the posts get updated new format entries get inserted so the =38 and =34 become obsolete and wrong. Always copy to a user variable and use a token as the format position gets updated automatically.
  1. Post Needed
    By YV600 in forum GibbsCAM
    Last Post: 09-25-2011, 04:12 PM
  2. Post Needed
    By mmcarr in forum Post Processors for MC
    Last Post: 12-07-2009, 08:06 PM
